wiper problem
kevscecotto
Thu Apr 27, 2006 5:49 pm
the wipers wont park on intermitant & washers on my 318is its not the relay as i tried that from my m3 ,anyone had this
Imagecool as the fonz!!
e30-320i
Thu Apr 27, 2006 5:51 pm
have a look in the articles section at top of page mate in technical
89 325i touring
e30-320i
Thu Apr 27, 2006 5:53 pm
89 325i touring
Gonzo-the-Great
Thu Apr 27, 2006 5:55 pm
I've had this problem on other cars and if it is'nt the relay then it usually is something to do with the wiper motor. I think there is a switch in there somewhere that tells it when to park. Fraid I am no expert but it may be worth a look!
Hope this helps 8)
kevscecotto
Thu Apr 27, 2006 6:59 pm
ok cheers guys ,ill give that a go 2moro
spiderrm
Fri Apr 28, 2006 11:57 am
Had exactly the same problem with mine. You need to take out the wiper motor, take off the gear cover and clean out and re-grease. Most probably dirty contacts. You can check the relay's OK by using a multi-meter on the plug and testing the switch settings. Easy job.
Fri Apr 28, 2006 12:49 pm
had the same prob last year , like the man says grease was the problem
Mart. :D
ps that link is brilliant!!
kevscecotto
Fri Apr 28, 2006 5:00 pm
fixed it now ,corroded track & contact also too much grease , working fine now ,only took an hour
