ta all
Engine looms are identical, and I've never had problems using the auto ECU.telski789 wrote:well all i know is its obviously a different box and flywheel,not sure about electrical side though? might be easier to put manual ecu and loom in,theyre stand alone anyway!
Tel
Help on what in particular?superted wrote:right i have started this weekend - well i have the car up on stands so far but im still lookin for info - help
I have three auto E30s in the collection, including a switchable.chu346 wrote:I paid some sukka to do it and regret it. Keep it an auto! (If it's switchable)
Not strictly true because the auto has a different throttle switch connector.Brianmoooore wrote:Engine looms are identical, and I've never had problems using the auto ECU.
Interesting. As luck would have it there's a 320 auto in the workshop at the moment, so I've just had a look.Templ8e30 wrote:Not strictly true because the auto has a different throttle switch connector.Brianmoooore wrote:Engine looms are identical, and I've never had problems using the auto ECU.
Also iirc there is an inhibitor switch so you can't start it in drive.
Iain T
I think I've solved the loom mystery, has your 320 got a switchable auto ?. Thinking about it I reckon the diiferent throttle switch has a seperate WOT switch to engage the kickdown but only on a switchable ?.Brianmoooore wrote:Interesting. As luck would have it there's a 320 auto in the workshop at the moment, so I've just had a look.Templ8e30 wrote:Not strictly true because the auto has a different throttle switch connector.Brianmoooore wrote:Engine looms are identical, and I've never had problems using the auto ECU.
Iain T
Sure enough, it has a different TPS and connector! BUT the recipient of my M50 touring started life as a 325 auto, and I've had a look at the engine that came out of that as well. The TPS on that one is the same as a manual one.
The starter inhibitor switch on an auto is a little sub loom with a relay that can be removed complete. It connects to the E30 starter circuit above the glovebox, where it plugs into two single pin connectors, both with black/yellow wire. When the sub loom is removed, you will find that the two remaining connectors in the car plug into each other.
Not true, have a look at the ETK parts catalogue and you'll find that they even have the same part number !WerkdE30 wrote:firstly someone said 320 325 flywheels are the same. not true the 320 has a lighter flywheel
Templ8e30 wrote:Not true, have a look at the ETK parts catalogue and you'll find that they even have the same part number !WerkdE30 wrote:firstly someone said 320 325 flywheels are the same. not true the 320 has a lighter flywheel
Cheers,
Iain T
