Gearbox Differences
iDemonix
Sun Jan 25, 2026 6:31 pm
Hi all,
I'm planning an M52B28 swap and have started acquiring parts. My plan is a 318iS gearbox with the 325i prop.
I've ended up with 3 gearboxes which are supposedly 318iS, however the last number differs on one, and I get different answers for why depending on who I ask - I've heard it's to do with internal casting, bearing size, output ratio, and some other bits....
Image of codes below. If anyone knows for sure, would love to hear!
240.0.0366.91 225 3.2
240.0.0366.91 225 1.4
minesapint
Tue Jan 27, 2026 2:00 am
With BMW Getrag 240 transmissions like the ones you’ve listed:
• “240.0.0366.91 225 3.2”
• “240.0.0366.91 225 1.4”
…both are the same basic gearbox casting/part number (240.0.0366.91) and both are 5-speed Getrag 240 manuals. The key difference is in the last number — 3.2 vs 1.4 — and that final group is widely believed among enthusiasts and tech forums to indicate a different internal specification such as gearset or final drive ratio.
📌 What the numbers likely mean
240.0.0366.91 – The main Getrag 240 transmission casting/part identifier.
225 – Secondary internal code that often appears on these boxes (likely batch/variant within the 240 family).
3.2 vs 1.4 – This suffix is not random — it refers to internal gearing or ratio variant rather than anything like model year, speedo drive presence, or number of gears. Two gearboxes with the same core casting can have different final drive ratios or internal gearing setups, affecting:
• Gear spacing / cruising revs
• Acceleration vs top-end gearing
• How the gearbox pairs with different engines or differentials
In other words:
• 3.2 would be one gearset/final drive spec
• 1.4 would be another, likely with different ratio steps
BMW/Getrag didn’t publish a simple public decoding sheet for these suffixes, so most of this knowledge comes from people physically comparing ratios and swap guides — but it does mean they are not identical inside even though the casing and main part number match.
What that means in practice
🔧 If you’re swapping one box into a car originally fitted with the other: you can bolt it in physically, but the driving characteristics (cruising RPM, acceleration, highway gearing) may change because:
• Different final drive or gear steps change engine RPM at a given road speed
• Speedo calibration or diff compatibility might need checking
📍 Neither suffix denotes a different number of forward gears — both are 5-speed manuals with the same basic Getrag 240 design.
For a BMW E30 318is, the correct / original gearbox is:
Getrag 240 – code ending in 1.4
So between the two you listed, the …225 1.4 is the 318is-spec box.
Why the 1.4 matters on a 318is
The E30 318is uses the Getrag 240 with the M42-specific gearset, which has these ratios:
Gear Ratio
1st 3.83
2nd 2.20
3rd 1.40
4th. 1.00
5th. 0.81
That 1.40 is the giveaway — the suffix is commonly understood to reference a key internal ratio (3rd gear) used to identify the gearset variant.
So:
• …1.4 → M42 / 318is gearing ✅
• …3.2 → different internal spec (typically from another engine application)
Same casing, same bolt pattern, but not the same gearing inside.
What happens if you use the 3.2 box instead?
It will bolt up and work, but:
• Gearing may feel shorter or oddly spaced
• Cruising RPM could change
• It won’t match the original 318is driving feel BMW intended
For originality, balance, and correct pairing with the 4.10 diff the 318is usually runs — the 1.4 box is the right one.
iDemonix
Wed Jan 28, 2026 1:25 am
Cheers, I asked ChatGPT too.
Unfortunately, it's easily suggestible, so I had it recommend both variants for seemingly the same reasons when asking on separate occasions... hoping someone might have some concrete answer, surprised how little info there is.
minesapint
Wed Jan 28, 2026 12:38 pm
Yeah exactly what GPT said.
I’ve been using it quite a bit recently, get some interesting responses plus a lot of BS.
rix313
Sat May 02, 2026 4:10 pm
It's pulled that gear ratio list from the wiki which I have been trying to confirm. It's actually been on my job list to compare ratios in my workshop. That wiki post is the only reference to any 240 ratios on the internet, which leaves me to be skepitcal about it. Watch this space. What will tell you for certain if it's a '318iS' box is if it has the extended output flange. You can easily check the ratios by marking the output shaft and turning the input, count the turns in each gear.
