Fuel leak
Cloggy Saint
Fri Apr 10, 2026 4:09 pm
Hi All, it's been many years since I posted, good to see the place still ticking over.
I have a big fuel leak that seems to be coming from the top right side of the tank but only when the engine is running. I've not had a chance to get underneath and give it a proper inspection, hopefully it's not a rusty tank as it isn't excessively old. What's the most likely culprit? Cheers.
rix313
Sat Apr 11, 2026 12:43 pm
High chance the old rubber hoses have started to fail at the ends.
Sat Apr 11, 2026 1:21 pm
Beware of new aftermarket fuel hoses, 95% of fuel hose is not fit for purpose, id highly recommend you buy from BMW
rix313
Sat Apr 11, 2026 3:52 pm
Excellent point. I made the mistake of (unintentionally) buying the wrong spec fuel hose and after only using E5 for two years I've already had to replace some. Make sure the hose you buy is from a reputable source and is R10 spec.
Cloggy Saint
Sun Apr 12, 2026 11:20 pm
Cheers for the replies. Can I more or less rule out a leaking tank as it only leaks under pressure, plus it's only about 1/4 full and the fuel seems to be coming from near the top. Re the hoses easily accessible? In all my years of ownership I've never really been near this area.
