Central Locking Noise
Kedge
Tue Dec 22, 2020 8:22 am
Hi,
My nearside central locking actuator seems to keep trying to operate after turning the key to unlock the car (can't remember if it does it on locking), it makes a loud buzzing type noise for a second or two.
Which is more likely to be the culprit, the actuator itself or the central locking relay?
Cheers,
Dave
Instagram - Kedge85
Contours
Thu Dec 24, 2020 9:37 pm
Actuator may be sticking. I would imagine if the others are working then that particular actuator is the problem
Fri Dec 25, 2020 11:04 am
More likely that what the actuator is trying to move is sticking. Clean and lubricate!
Kedge
Fri Jan 22, 2021 6:12 pm
Cheers, I'll try and find some time and motivation to strip the door down and give it a proper investigation. Hopefully does just need a clean and lube.
Instagram - Kedge85
HenryM3
Fri Jan 22, 2021 8:42 pm
I had exactly this problem a few weeks ago, I sprayed wd40 in through the key hole and the door shut side of the lock. This cured the problem, I then sprayed bike chain lube in same areas. Been working fine since. Will at some stage strip and clean but to cold at the moment.
