I am gearing up to replace my sunroof (have to have the replacement I have resprayed) and read that the bolts should be replaced. I have thought instead to use a threadlock and wondered if anyone has done this job(especially a while ago and not had any issues with the bolts coming loose). Also any advice about the job at all is welcome.
Sunroof bolts
BristolE30
Do you mean just the sunroof panel? I removed my sunroof panel to put a new seal on it, reused the same bolts and no issues heremickes wrote: ↑Mon Feb 24, 2020 5:55 pmI am gearing up to replace my sunroof (have to have the replacement I have resprayed) and read that the bolts should be replaced. I have thought instead to use a threadlock and wondered if anyone has done this job(especially a while ago and not had any issues with the bolts coming loose). Also any advice about the job at all is welcome.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
BristolE30
- Brianmoooore
The only bolts that need renewing on anything, unless damaged, are stretch bolts, and the sunroof bolts definitely aren't those.
I think that the bolts in question have a serrated area under the head as a locking device. In theory, this will be damaged when the bolt is undone, but a little threadlock is more than an adequate replacement.
BristolE30
Agreed!Brianmoooore wrote: ↑Wed Feb 26, 2020 1:45 pmThe only bolts that need renewing on anything, unless damaged, are stretch bolts, and the sunroof bolts definitely aren't those.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
