Bmw e30 touring driveshaft allen bolt stripped
quick_silver
Mon Mar 14, 2016 2:37 pm
I started today to take the driveshaft off the diff so i can remove the whole diff for a new one. Taken every allen bolt out of the drive shaft then gets to the last one. Its that corroded that its stripped as soon as i tried to turn it. What other way can i go about removing it??? I was close to just cutting the head of with a grinder. Any advise will help cheers
Also take 4 17mm bolts off the propshaft but thread sticking through, can you just pry it so it moves back?? or can i wiggle the diff out when everything is undone?? Thanks
Dlb26
Mon Mar 14, 2016 3:32 pm
When you say stripped do you mean the thread or the hex?
quick_silver
Mon Mar 14, 2016 9:46 pm
Yeh the thread in the hex. If i cut the head off i might wiggle the diff out. But i rather try getting it off the right way
Topblag
Mon Mar 14, 2016 10:00 pm
Weld a nut onto it. Next time try this....
give the head of the bolt a few whacks with a hammer with a socket over it, turn it to tighten a little, then reverse and try to remove. Worked for me on an abs sensor Allen bolt, and it was smaller.
Use lots of wd40 or equivalent also.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
quick_silver
Mon Mar 14, 2016 10:47 pm
I cant weld to save my life, i can cut the head off coz the diff is fooked. i wacked it in but looks like previous person damaged the thread. Ill have to just get it out
