Oil in air filter LOADS COMING THROUGH INLET PORTS
DazzyA
Sat Jan 14, 2006 10:30 am
Just noticed quite a bit of oil on my air filter heat shield. Removed afm and pipes and oil in afm and throttle body. I assume there shouldn't be oil there and wondered where it could be coming from. Any help would be gratefully received.
Pass me the spanner
DazzyA
Sat Jan 14, 2006 12:40 pm
bump
Pass me the spanner
Ant
Retired Team Member
Retired Team Member
Sat Jan 14, 2006 1:15 pm
The main breather from the crankcase is routed to the TB and will pull up the odd bit of oil now and again.
Once up in the TB any "excess" will gradually worm its way down the intake bellows and collect around the air filter, with a std airbox its not uncommon to find a small amount of oil in the bottom
HTH
DazzyA
Sat Jan 14, 2006 2:04 pm
not too bad then, seems a fair bit though, will put standard air box back on I think.
cheers ant.
Pass me the spanner
DazzyA
Sat Jan 14, 2006 4:26 pm
Seems I have oil coming through inlet manifold ports 4,5 & 6, does this mean head gasket or valve seals or similar?
Pass me the spanner
r_9ore
Sun Jan 15, 2006 11:16 am
Not positive on this one but my mate over filled his punto sporting with oil one time, he ended up with oil coming out the his air filter.
it was just the build up of pressure as there was too much oil in it and it just blew most of his seals.
im not saying its the same reason but it sounds similar. have you checked oil level or changed it recently?
DazzyA
Sun Jan 15, 2006 1:35 pm
oil was changed last week, I thought it seemed to take more than recommended, may be an air lock somewhere will start again.
cheers faor that, never crossed my mind.
Pass me the spanner
