Hi everone
My head unit has loss power completely. Nothing else has stopped working.
I have no idea about car electrics. Where do I start?
Head Unit No Power
- PaddyEnglish
i'll check both and let you know.diable wrote:The head unit may have a separate fuse in either the unit or behind it, you may need to pull it out to check.
Does your cigarette lighter work?
Thanks for replying.
- PaddyEnglish
Hello mate. My cigarette lighter is working and the fuse at the back of the head unit is fine. Is there anything else I can check?diable wrote:The head unit may have a separate fuse in either the unit or behind it, you may need to pull it out to check.
- PaddyEnglish
I bloody hope not! It's less than a year old.
Ok, thanks for the advice. I'll get myself a voltmeter.
