central locking keeps locking,
asmith88
Thu Mar 08, 2012 10:44 pm
only does it when the ignition is on, a few moments after putting the key in the doors will lock, if i release them a few moments later they will lock again,
caught me out the other day and the keys got locked in the car,
any ideas?
1990 brilliant red 318 is
Fri Mar 09, 2012 8:32 am
Probably an aftermarket alarm acting up.
asmith88
Fri Mar 09, 2012 9:12 pm
no aftermarket alarms in it,
Jos
Fri Mar 09, 2012 10:09 pm
It does sound like an anti -hijack type thing. If you are 100% sure there isn't a box 'o tricks lurking up under the dash somewhere, I think the lock notify is earthing of pins 7 or 8 on the central locking unit, might be earthing to the body somewhere.
'94 e36 tree climber
Minimayhem81
Fri Mar 09, 2012 10:12 pm
Think it might be a dodgy 4 pin relay above the glovebox area?
Fri Mar 09, 2012 11:13 pm
Minimayhem81 wrote:Think it might be a dodgy 4 pin relay above the glovebox area?
Nothing in this area relevant to the locking.
There are a lot of alarm/immobilisers in E30s that their owners know nothing about! More than one in many cases.
asmith88
Sat Mar 17, 2012 6:58 pm
i went to fit a aftermarket alarm about 2 years ago, the alarm unit was dodgy and i got my money back, never bothered getting at it again,
everything has been fine since then and its only started recently, its intermittent, but i cant trust it leaving my keys in, with the ignition on,
Sat Mar 17, 2012 7:36 pm
Well, if there's no aftermarket alarm fitted, the only things it can be is a locking ECU with a fault I've never come across before, or an intermittent short to earth of the lock request wire, caused either by a dodgy wire or something wrong with one of the lock request switches, again, something I've never come across.
asmith88
Sat Mar 17, 2012 10:13 pm
il get the door card off tomorrow, hopefully just the microswitch jammed
