M3 trailing arms question?
colin325
Sat Feb 25, 2012 2:25 pm
Can E36 M3 trailing arms be used on an E30? If not then why? are e36 compact trailing arms a good substitute for upgrade on rear disc set up if I can't use the m3 ones? If I'm goin to swap over the suspension from the M3 then will I keep the stock shocks and springs or bilstein shocks and decent uprated springs? The stocks ones are in really good condition, just wondering in the lighter shell for track day use ONLY will it stand to me later to uprate it now while in the build state?
Any advice welcome.
e21Jason
Sat Feb 25, 2012 3:00 pm
No as e36 m3 do not use trailing arms, but compact arms can be used.
If you have an e36m3 it will make a better track car than an e30
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
colin325
Sat Feb 25, 2012 3:17 pm
It's a soft top, plus if I like e36's I wouldn't be on dis site ha ha it's got to be e30 for me I'm afraid! They don't use trailing arms? What do they use? :)
e21Jason
Sat Feb 25, 2012 3:47 pm
e30 rear axle
e36 rear axle
also only e36 m3 evo suspension is a direct bolt onto an e30
Z3M Coupe for sale
69 Alfa spyder
colin325
Sat Feb 25, 2012 4:05 pm
Thanks for the info, so I know the front suspension and brakes will swap over what your saying is only the evo rear axle setup will swap over? Correct? Just to confirm before i go out and get it. Thanks again!
mrLEE30
Sun Feb 26, 2012 12:23 pm
No he is saying m3evo fronts will fit, the rear will not. You need z3 rear set up assuming you want to go for a 5 stud set up, the arms themselves will not improve your rear set up- to do that you need better shocks, springs, bushes and anti roll bars, it's also worth strengthening the arb mounts as they can bend.
colin325
Sun Feb 26, 2012 11:22 pm
Top man thank you, well I'll go for whatever setup that leaves me run with the M3evo rear brakes...
Either z3 or compact arms... Guess I'll be searching for a while!!
e21Jason
Sun Feb 26, 2012 11:29 pm
rear M3 r brakes only fit z3m arms which are about £500 used.
also read this
http://www.e30zone.net/e30zonewiki/inde ... Conversion
Z3M Coupe for sale
69 Alfa spyder
