Hi guys got a new (second hand) AFM and fitted it to my 1986 325i (Older high comp engine) engine doesnt seem to pull as strong since i fitted it and want to check that the co screw is set right, can anyone tell me how many turns out they should be roughly?
I.e if you wound it all the way in and then turned it out to the right point how many full turns would you need?
Thanks for any help
Ad
