Thermostat - 92c instead of 88?
Ednamillion
Tue May 31, 2011 8:04 pm
Just going to get some belts changed on the M40. I happen to have a 92c thermostat (for an M50) realoem indicates that the m40 uses the 88c. The m50 can take either....Could I put the 92c into the m40? Any particular downsides?
lemmy99
Tue May 31, 2011 10:37 pm
faster warm-up in the winter, chance of over-heating in a traffic que in the summer.
Wed Jun 01, 2011 12:14 am
M40 uses a 1.4 bar pressure cap, while the M50 runs at 2.0 bar. Running the higher temp. stat. at the lower pressure increases the risk of local boiling in the hotter parts of the head.
Ednamillion
Wed Jun 01, 2011 11:10 am
lemmy99 wrote:faster warm-up in the winter, chance of over-heating in a traffic que in the summer.
Cheers lemmy99.
Ednamillion
Brianmoooore wrote:M40 uses a 1.4 bar pressure cap, while the M50 runs at 2.0 bar. Running the higher temp. stat. at the lower pressure increases the risk of local boiling in the hotter parts of the head.
Brian, I can check this out myself, but do you know off hand if the caps are interchangeable....?
**BANNED**
Wed Jun 01, 2011 12:25 pm
Reason that E30 cooling systems use the lower pressure cap is the known problem with the heater matrix/valve just above the passenger's legs.
These are known to spray hot coolant onto unsuspecting passenger's tootsies,so BMW initiated a re-call to fit E30 with the 1.4bar cap.....
Youth is wasted on the young.
lemmy99
Wed Jun 01, 2011 4:02 pm
and what Brian said.
In the good old days, changing to a winter thermostat and lighter engine oil was the norm until the intervention of higher pressure systems, multi-grade oils and radiators that didn't piss on your plus fours if you forgot the 200% anti-freeze mix.
That's was also providing you managed to crank the handle fast enough to get it started in the first place.
Wed Jun 01, 2011 7:28 pm
The mighty E30 318iS uses a 2.0 bar cap as standard.
Ednamillion
Wed Jun 01, 2011 7:46 pm
daimlerman wrote:Reason that E30 cooling systems use the lower pressure cap is the known problem with the heater matrix/valve just above the passenger's legs.
Hmmmm....so a 92c stat with a 2bar cap may still be a problem on an M40? (The caps seem to be interchangeable....).
