Starting problem?
- Brianmoooore
Connect a pressure gauge into the rubber fuel hose to the injector rail, and see what happens to the fuel pressure with the engine off.
- Brianmoooore
Marked on the pressure regulator.
3 bar for a 325, but this is relative to the pressure in the inlet plenum. Should be 3 bar with the throttle wide open dropping to around 2.4 bar with the throttle closed when the engine is running.
