Happens when the brake pedal is pressed. also very little in the way of any brakes.
All help appreciated
Pressure release sound from passenger footwell
gareth
The servo will make a slight 'pish' noise from behind the glovebox when you press the pedal, this is normal.
What's the problem you have with the brakes?
