hotting up
tomk
Sat Jul 24, 2010 9:35 am
My 325 touring temperature gauge has recently started to creep up over the half way point when in traffic up to about three quarters. It seems fine on open roads.
Is it time for a new radiator (the existing one looks very tired)or is it some other problem?
I've flushed the system and the original water looked all clean, not rusty etc.
Any ideas?
bobbin1982
Sat Jul 24, 2010 9:37 am
water pump maybe
Driving my digger!!!!
tomk
Sat Jul 24, 2010 9:45 am
Thats a possible, hasn't been replaced for 50,000 miles. But the radiator is even older!
Sat Jul 24, 2010 10:05 am
It's normal for the temp. to go up slightly in traffic, but not by much.
When driving at normal speeds the forward motion of the car provides sufficient airflow through the radiator, but in traffic this function is taken over by the engine driven fan.
This fan is coupled to the water pump by a viscous coupling which normally allows the fan to free wheel, but locks up when it detects hotter than usual air coming from the radiator.
This lock up doesn't seem to be happening in your case, so the viscous coupling has probably failed.
tomk
Sat Jul 24, 2010 10:15 am
Thanks Brianmoooore, Will have a look in the Haynes manual as need some more info.
What's required to replace?
Sat Jul 24, 2010 10:21 am
One viscous coupling and a 32mm open ended spanner.
**BANNED**
Sat Jul 24, 2010 11:39 am
Fan unit has a reverse or left hand thread....to remove it belt your spanner the opposite way to normal!
Draper make a special 32mm spanner correctly shaped for this job.
Youth is wasted on the young.
tomk
Sun Jul 25, 2010 7:52 pm
brilliant thanks guys.
mrLEE30
Mon Jul 26, 2010 7:06 am
if your water pump is 50,000 miles then your timing belt will be of similar age most likely, while you have the fan off i would change the cam belt, waterpump and tensioner, can be done with average home tools and average home mechanic
TPS
Mon Jul 26, 2010 7:09 am
I did the job once, so it must be simple!
