E30 IX running gear ??? Anyone tried converting to 4x4?
turk
Mon Mar 29, 2010 6:23 pm
Ive been bored frankly so was looking into how doable swapping the IX running gear into a 2dr e30 would be??
Anyone tried? whats involved and do u have pix???
More of a chat topic really... oh well...
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Grrrmachine
E30 Zone Wiki / Team Member
Mon Mar 29, 2010 6:58 pm
Don't think it's a straight swap. Running gear includes front legs, steering rack, oil sump, as well as the usual gearbox/diff/prop/driveshaft issues. There MIGHT also be some actual body differences, but I can't remember.
I looked into all this a year back, as my car has the paperwork of a 325iX despite being a 320i mechanically. Good old dodgy imports ;)
turk
Mon Mar 29, 2010 7:23 pm
Happy days :D Might just look for a tatty ix to do up, probably cheaper too... I know u need a short engine if its to be attempted, and legs with shafts etc, 2 props i think :roll:
oh well i can dream
Sump Baffles
TrackDays
Grrrmachine
Mon Mar 29, 2010 7:33 pm
Yeah, did a search for my old thread. Chassis is different, especially front turrets. Plus, the 4x4 running gear has fragilities - the yanks do all sorts of mods to the drive shafts to make them penetrate the hubs deeper.
Quattro ist fur sissies, anyway
8)
tomson
Tue Mar 30, 2010 1:42 pm
As said the front turrets are slightly differant and the transmission tunnel is wider on an iX. I have all the running gear spare if you fancy a project winkeye
Grrrmachine wrote:Plus, the 4x4 running gear has fragilities - the yanks do all sorts of mods to the drive shafts to make them penetrate the hubs deeper.
The front driveshafts fully pass through the hubs with a large nut on the front just like rear E30 shafts do so I dont know how they modify them :?
turk
Tue Mar 30, 2010 2:20 pm
Theoretically then :D what would need to be done to a standard 2 door e30 in terms of squeezing all the extras in? Lump hammer to the tranny tunnel Im guessing? And locate a short engine. And I doubt it would work with my m52 :(. German eBay me thinks
Sump Baffles
TrackDays
dips346
London Meets Main Man
Tue Mar 30, 2010 2:25 pm
pretty sure even the engine block is different
tomson
Tue Mar 30, 2010 3:03 pm
turk wrote:Theoretically then :D what would need to be done to a standard 2 door e30 in terms of squeezing all the extras in? Lump hammer to the tranny tunnel Im guessing? And locate a short engine. And I doubt it would work with my m52 :(. German eBay me thinks
The transmission tunnel would need more than a beating I fear !
You would need a sump and oil pick up from an E34 525iX to use the M52 donk winkeye
As dips says the M20 block is different underneath for the oil pick up & pump to a normal M20 block, I also have one of these here winkeye
Falkster
Tue Mar 30, 2010 4:19 pm
I've got an iX that is in the process of being rebuilt. It's had a full respray, I'm just getting last few bits of trim.
turk
Tue Mar 30, 2010 4:22 pm
Have u got a build thread? Would be v. Interested to see.
Sump Baffles
TrackDays
turk
Tue Mar 30, 2010 6:59 pm
tomson wrote:As said the front turrets are slightly differant and the transmission tunnel is wider on an iX. I have all the running gear spare if you fancy a project winkeye
Lets talk munney :bling:
Sump Baffles
TrackDays
tomson
Tue Mar 30, 2010 10:28 pm
Depends if you want a switchable auto or manual iX gearbox winkeye
PM me if your serious :)
handpaper
Wed Mar 31, 2010 5:13 pm
Grrrmachine wrote:Yeah, did a search for my old thread. Chassis is different, especially front turrets. Plus, the 4x4 running gear has fragilities - the yanks do all sorts of mods to the drive shafts to make them penetrate the hubs deeper.
8)
The weak point as I recall is the driveshaft where it enters the front diff. Tends to strip its splines.
StevenC3828
Wed Apr 07, 2010 1:54 pm
handpaper wrote: The weak point as I recall is the driveshaft where it enters the front diff. Tends to strip its splines.
handpaper / guys do you mean the where propshaft enters the transferbox?
Moonlite motorwerks do a spacer for the front prop shaft http://www.moonlitemotorwerks.com/driveshaft
Wed Apr 07, 2010 2:07 pm
I didn't think you had any ? :?
turk
Wed Apr 07, 2010 3:20 pm
Price enquiry that's all. Probly gonna sell mine to fund new project. :)
Sump Baffles
TrackDays
