E36 M3 exhaust manifolds
benjy
Fri Jan 01, 2010 6:44 pm
Does anybody know exactly what type of stainless S50 manifolds are actually made from??
Cheers, Ben
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Cook318IS
Fri Jan 01, 2010 7:42 pm
Just looking on ca automtive and ruff products stainless manifolds are listed on there, and it shows them using SUS 304 / T304 or whatever its called. Turner motorsport list themselves using T304 for the new E9X 3 series for the likes of the 335i.
http://www.ca-automotive.co.uk/products ... 9Mg==.html
Worth giving dave a ring to see what he uses?
benjy
Sun Jan 03, 2010 2:10 pm
I know that most use 304 or 308 for their SS manifolds but what are the originals made of??
I can weld them with MS wire but then the welds will rust and it makes a difference as to which wire you use on which base metal. You can use a 'higher' grade of wire but not a lower i.e. 308 wire on 304 or 308 metal but not on 316.
