speedo help pls
Hi there i have just put my dash back in and have noticed that fuel gauge isent working stuck on half, and my speedo has stopped working but that wasent working befor the dash come out has anybody had this problem or someone know whats wrong thanks
Don't have a clue how to fix it but there are loads of second had clocks on parts for sale £10 upwards and it could be a swap of the dial.
I assumed you have wired it up right!
- Brianmoooore
Is it the same fuel gauge, that used to work properly, or have you fitted a different one?
- Brianmoooore
What model and age of car? Or what fuel tank does it have?
- Brianmoooore
Take out the rear seat base, remove the RH inspection cover, and pull off the plug to the level sender.
Does that send the gauge to zero?
- Brianmoooore
How much fuel is actually in the tank? Does filling the tank make the gauge go to full?
- Brianmoooore
Either you have the wrong fuel gauge for your tank (6 pot gauge with a 4 pot tank), or one of the senders, in a tank with two senders, is stuck in the full position.
- Brianmoooore
Take out the rear seat base, and take off the two inspection covers.
Is there a level sender under each one?
Do you have an electrical test meter?
Do you know what a resistor is and/or do you have any?
- Brianmoooore
Brianmoooore wrote: Is there a level sender under each one?
