can anyone point me in the right direction / give any advice?
is this somthing i can undertake myself or will i just have to bite the bullet and hand over some cash?
Ive just bought some BMW motorsport bushes from BMW at £83 + vat each and there is no movement in those, even less than what you would get from polly bushesBrianmoooore wrote:Fitting new bushes isn't much of a problem - it's getting the old ones off that may be the trouble.
Use genuine BMW bushes, not aftermarket stuff, whether it's made of poly or rubber.
The rear beam is supposed to move slightly under load, as part of the suspension design.
They look identical to the stock ones, they even have with the cut outs at the side. They use what looks like another type of material because they are very very stiff!DanThe wrote:Are they solid rubber Andrew? Got a part number and any pics?
