Cab roof motors.
Spike121
Mon Mar 23, 2009 7:29 am
Hi All, New to the zone and loving it, just got myself a project, a brilliant redish :? 325 cab. Needs a lot of TLC.
The main roof motor is broken at the pivot point is there a repair/replacement part for this? if so where can i get a hold of it? also i have removed the main motor and now the horseshow motor does not work, do they both need to be attached as i cant lock the horseshoe down.
Many thanks
Spike.
DaveD
E30Zone Wiki Specialist
Mon Mar 23, 2009 8:16 am
The e30 centre at Darlaston in the west midlands produce a new top half motor shell in cast steel rather than monkey metal , for about £100 and will fit it for you if you ask nicely..
e30 centre...
the no is 07871 662 902 jason
07968 852395 bill
The horseshoe motor should work if the roof motor is disengaged ...mine did,, but I do not know where the fuse is ....but have you taken it out? you might have disturbed something?
best of luck
Spike121
Mon Mar 23, 2009 9:08 am
Nice one dave, will give them a call, bit far to go as I`m down in kent, thanks for the quick reply.
Spike.
DaveD
Mon Mar 23, 2009 9:22 am
you might be a long way away but it would save you a lot of probs going to visit them as getting the sequencing right can be a prob....
Spike121
Mon Mar 23, 2009 9:44 am
Yeah have read that, will take a drive up when i get my new hood, would`nt want to buger that up, cheers.
grantfk10
Mon Mar 23, 2009 9:47 am
Sorry for slight hi-jack of this thread, but what oil/grease would you recommend for servicing the cab roof?
DaveD
Mon Mar 23, 2009 12:41 pm
Spike121 wrote:Yeah have read that, will take a drive up when i get my new hood, would`nt want to buger that up, cheers.
If you are having a new roof fitted get the motor part as the fitters will know how to sync it
grant
I use that spray grease or a solid grease (forgotten which 'cos its in a tub in my garage)....
