relay in fusebox problem
sohood
Wed Nov 19, 2008 6:11 pm
had a problem with heater blower and electric windows not working on my 325i cabrio... changed the relay above gearbox (changeover one) and the windows were working fine.. then out of the blue they stop working and now there is no power to that relay... i checked the fuse... there is no power to fuse 17 or to any to the left of it...i changed all the unloader relays for spares i had and still nothing.....
any help will be appreciated.. i have done a search and have found loads of info on door switch problems etc but doesnt really help with this prob
zaust
Zone day release
Wed Nov 19, 2008 7:00 pm
The comfort relay and connecting plug's are behind/back left of the glove box, Would start there now...
M30 Tech 1 Touring on gas.
SPADGE
Wed Nov 19, 2008 7:45 pm
Check the connection of the small wire going to the starter motor
sohood
Thu Nov 20, 2008 1:55 pm
ive fitted a new "comfort relay" it seems there is no power going to it. everythign else on the car works fine, the interior lights work fine with the door switches etc...
SPADGE
Thu Nov 20, 2008 2:34 pm
SPADGE wrote:Check the connection of the small wire going to the starter motor
:poke:
sohood
Fri Nov 21, 2008 12:59 am
:poke:
checked it, its ok!
Fri Nov 21, 2008 9:19 am
Check it again.
