Hi guys
What are the advantages and disadvantages of fitting the eccentric track control bushes?
If anyone could explain the principal that would be great
I have done a search but there were loads of irrelevant posts and my eyes went square!
Chris
m3 track control bushes onto 325i sport
- zimmerbimmer1
- BMW Parts Meister
The wheels are moved slightly forward in the arch improving the turn in of the car for better handling as far as I am aware.
- **BANNED**
Improve castor angle.The bushes are also solid,so they improve location.Turn in is improved as is steering 'feel'. Only downside is that the steering feels very slightly heavier.You may find that the front tyres rub on the front of the arch liner on full lock.Do it,well worth the effort.
Youth is wasted on the young.
maybe a silly question but what would happen if these are fitted with the off set hole 180 degrese out?.... also is there anyway of removing the bush from the arm and bracket to correct this?.... if need be i would cut the bracket to remove the bush from this.... any ideas?....
Got them on!
I did the ball joints and anti roll bar drop links and the front end feels amazing!
Really recommend the M3 bushes the car turns in so much better,
Pressing the ball joints in and out is not recommended though buy the whole arm(s) if you can!
