Fri Jul 04, 2008 10:58 am
in that case try checking the oil filter and replace o-ring afterwards.
also, is your gearbox sides seeping with oil? oil could leak from either the front or rear crank seals (if from rear crank, oil could seep on the gearbox), and also is your fan cover oily?
this is really odd...
oh yea! one vital question: do you see oil under the engine when you leave the car for a day or in the morning? if its not, i think its going somewhere else
