4 stud to 5 stud ????????
luke123
Tue Jun 03, 2008 8:58 pm
hi i want to buy these old bmw bbs off of a 633 e24. i know they are 5 stud but what is the pcd??? also can you get adapters from 5x??? to 4x100
thanks luke
Jonsku
Wed Jun 04, 2008 8:27 am
4x100 => 5x120 adapters can't be made (bolts are partly over each other).
You can make E30 5x120, but it requires M3 parts or E36 front struts with E36 M3 stuff + Z3 / E36 compact rear trailing arms with all parts.
So it's not easy nor cheap, easier to find correct rims..
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
smithy318i
Wed Jun 04, 2008 8:39 am
Jonsku wrote:4x100 => 5x120 adapters can't be made (bolts are partly over each other).
+1.
Just buy wheels with the correct offset and PCD.
Hell of a lot cheaper.
Adapters can be made. but alter the offset by 20cm.
