Overfilled oil
Philwild
Tue May 20, 2008 2:53 pm
A friend of mine (ahem :o: ) has an E30 325i Cab being a bit of a bell end, he has overfilled the oil slightly.
The oil level is now about 5-7mm above the max mark on the dipstick and you get a nice cloud of blue smoke on startup which stops soon after.
Have I - I mean has he :wink: - buggered anything up?
1992 Mauritius Blue 325i Cabriolet.
rj
Tue May 20, 2008 3:09 pm
An over filled engine can create problems, so "your friend" would be advised to drain some of the oil out to correct the excess amount.
bilun777
Tue May 20, 2008 3:16 pm
Ditto, drain some out,thats over 2 inches and if the crank webs or conrods are running in it He'll have alot of black air filled mayonnaise being pumped around the engine......not good... :(
If it aint broke don't fix it!
Chase007
Tue May 20, 2008 3:20 pm
Jack it up and pull the plug on the sump it is not that hard trigger! 8O
Philwild
Tue May 20, 2008 3:31 pm
Thanks Chase - I realise that I need to drain some out....I'm not quite in Trigger's league.
Its just that I cant do it until I get home and I need to drive the car to get it home. I was wondering if it would bugger it up driving it.
Philwild
Tue May 20, 2008 3:37 pm
BTW, it looks like Bilun777 may have thought i said 57mm over max. It is 5 to 7 mm over so not quite that bad.
I only noticed the puff of smoke at work this morning when I started it. I assume that once some has been drained out, the extra will burn off and the puff of smoke will dissapear?
march109
Tue May 20, 2008 4:26 pm
Yeah it should, can't you borrow beg or steal a spanner at work to sort it now though? you litterally only need to drain out a bit of oil. 5-7 mm is probably only a couple hundred mm, could catch it in an old milk bottle.
Philwild
Tue May 20, 2008 4:39 pm
Yeah, I'll see what I can do. I work in an office so might be tricky!
Cheers guys, I hope I haven't broken it!
Tue May 20, 2008 9:25 pm
march109 wrote: 5-7 mm is probably only a couple hundred mm, could catch it in an old milk bottle.
millilitre even? :)
Personally, I would leave it. Being an M20 it wont be in there for long :P
bilun777
Tue May 20, 2008 9:27 pm
Philwild wrote:BTW, it looks like Bilun777 may have thought i said 57mm over max. It is 5 to 7 mm over so not quite that bad.
Yes you're right.... I wondered how you could have accidentally put in half a gallon of oil? :o:
Philwild
Tue May 20, 2008 11:57 pm
I didn't manage to drain some off at work so had to drive it home. No puff of smoke at start up so looks like DanThe is correct! S'all good....
Chase007
Tue May 20, 2008 11:58 pm
Ok Philwild i will retract that i did think by reading 2 fast and seeing Bilun777 think near 2inches it was more, Ok next time do your maths before u act lol :D :cool:
