Cutting out problem!
dubnut_8v
Sun May 04, 2008 7:27 pm
Got a problem with my 320 se g reg
Basically its cutting out an juddering violently when you put your foot down on the accelrater pedal ive cleaned the tb with carb cleaner but nothings changed.
It only started occuring yesterday an has gradually got worse im really lost as i know no bmw specialist near me if you can help it would be much appretiated.
cheers , Tim
ucpsale
Sun May 04, 2008 7:40 pm
Do the electrics cut out as well?
siddiqi1
BFG Zone Contributor
Sun May 04, 2008 11:18 pm
have a look at this thread, covers most things you should be looking at buddy
Click here
Regards
Saboor
georgen
Mon May 05, 2008 12:30 am
Sounds like your distributor cap has a big crack in it. Take the bugger off and have a good look at it.
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
dubnut_8v
Mon May 05, 2008 3:37 pm
UPDATE.. I called the AA out an he said the coil was'nt sparking so he got a red wire from the coil with a connecter an a seperate red wire from the battery an has a fuse an basically once you connect them the cars fine obviously i have to undo them when i park up an go through opening the bonnet an connecting them but its only a temp fix until i find the problem.
siddiqi1
Mon May 05, 2008 6:38 pm
cant have been your coil; was the car idling ok?
it wouldnt even want to start if the coil was a goner!
