e30 quick racks
andyr
Fri Mar 14, 2008 11:03 am
Hi guys,
I was wondering if you know off any where i can get my hands on a quick rack for the 320. Its g reg with power steering at mo.
Thanks, ANdy
blitz877
AKA ajm-e30
Fri Mar 14, 2008 11:17 am
get a z3 rack mate
DRIFTBOY
Fri Mar 14, 2008 11:24 am
E36 rack is a good upgrade for the E30 too, and cheaper and easier to find than the Z3 one, although not quite as good.
You'll need to mess about with pipes and the coupling for either of these.
Have a read of this!
http://www.e30zone.net/modules.php?name ... ic&t=45398
odbod
Fri Mar 14, 2008 10:01 pm
Z3 is great!!! :cool:
Dave_M3
Sat Mar 15, 2008 12:50 am
I can't seem to find a feckin Z3 rack yet :cry:
E36 racks everywhere :roll:
An E46 rack is nice too. around 3.2 turns lock to lock and much tighter since it's alot younger :wink:
madaboutthe30
Sat Mar 15, 2008 1:14 am
How comes the z3 rack is so good?
I thought my current one was good, the turning circles never fail to suprise me and I got a standard rack in there
Dreaming of the day I purchase an E30 M3
--- e30 motorsport cab-- in the process of becoming a trailer queen
--- Z4M Coupe - daily driver
DRIFTBOY
Sat Mar 15, 2008 1:28 am
The standard E30 rack is possibly the worst bit of design on the whole car!
It's awful! :(
Way too much arm twirling required to go round any corners, and you have to work fast when getting an E30 sideways with a standard rack! 8O
E36 rack is a much nicer ratio, especially for the money they cost (don't be fooled into buying an E36 M3 rack at extra cost, they are no better!).
If you can afford it, and if you can find one, a Z3 rack is even better though.
Much more responsive and satisfying steering to be had from either of these. Makes the car much nicer to drive. :D
Odbod - that is a fine looking car you have there! :cool:
madaboutthe30
Sat Mar 15, 2008 1:30 am
Ok cool, that makes sense
Dave_M3
Sat Mar 15, 2008 2:12 am
Gibson
Old Ford Deviant
Sat Mar 15, 2008 2:25 pm
Hiiiiiiiiiiiiiiiiiiiiiiiijackkkkk
whats the easiest one to fit? bearing in mind i dont have a ramp or machine shop i need something that can be done on axle stands without any machine work needed....
Dave_M3
Sat Mar 15, 2008 3:02 pm
They are all the same. Same work needed for all of them.
For an iS, you don't need the adapter for the U-J though since you'll only be mounting it on the front holes of the subframe.
I done mine on two concrete blocks and a few bits of wood under the chassis rails :roll:
andyr
Sat Mar 29, 2008 7:22 pm
Ta for all suggestion guy, i'll have a route about see what i can get my hands on
Dunx
Sat Mar 29, 2008 7:39 pm
Ive read before that you cant use them if you have a btb 6branch.... this still the case? or has someone figured out a way to do it?
mikekean
Sat Mar 29, 2008 7:58 pm
yeah id like to know this aswell.
maxfield
Sat Mar 29, 2008 8:03 pm
I'm pretty sure there are a couple that run it with the 6branch.
