repairing jacking points
kevin316i
Tue Jun 07, 2005 11:42 pm
There is some rust on my jacking points and to make things worse, I used a trolley jack with a raised edge on its lift which has dented the sill at the jacking point :cry: .
Would it be an easy job to repair this area, or will I be left with a constant reminder of my stupidity?
dazleeds
old skool raver
old skool raver
Tue Jun 07, 2005 11:45 pm
me too :yeahthat: dohh
www.oldskoolfantasy.co.uk
kevin316i
Wed Jun 08, 2005 11:02 pm
Looking at the rust this evening it looks like bad surface rust around the jacking point, so I'm thinking get the rust treated and the sills schutzed? I still feel like a plonker for denting the lower sill line. These dents can't be removed :roll:
smithy318i
Wed Jun 08, 2005 11:32 pm
Sounds like a plan!
Jacking the car with a trolley jack on the SILL :mad:
FYI... E30 Jack points.
http://www.r3vlimited.com/Tech/Jackpoints.jpg
dazleeds
old skool raver
old skool raver
Wed Jun 08, 2005 11:46 pm
smithy
like you can talk :lol: :lol:
is that anyway to park ya beemer :lol: :banghead: :lol:
smithy318i
Wed Jun 08, 2005 11:53 pm
My parking is normally good.
except when im running late
:lol:
example...
Hani
Wed Jun 08, 2005 11:56 pm
That how BMW drivers are supposed to park.
320Touring
Thu Jun 09, 2005 12:54 pm
smithy318i wrote:My parking is normally good.
:lol:
example...
its actually just trying to not catch anything off of the punto :lol:
kevin316i
Sat Jun 11, 2005 11:58 pm
Don't mean to be rude, but has anyone got any constructive feedback to help answer my question?
Karan
Sun Jun 12, 2005 12:43 am
some photos would help mate.....
anything can be done....
the floorpan u talk about can be done easily using a cutout from another e30....dunno bout the sills as thse are visible everyday so i dunno if perfect finish could be acheived
golf_killa
Sun Jun 12, 2005 12:45 am
had rusted jacking points on my 318i, got them sorted though and it only cost Ԛ£75 for both sides! and this wasnt a cowboy job but from a very reputable bodyshop.
Adammcf
Sun Jun 12, 2005 1:28 pm
Best option is probably to fit two new sills. If the jacking points are that bad then the sills are probably the same.
Karan
Sun Jun 12, 2005 2:21 pm
Adammcf wrote:Best option is probably to fit two new sills. If the jacking points are that bad then the sills are probably the same.
sills are pretty solid on e30s and most times rusty jackin points are quite localised.... but occasionally spread onto the lateral chassis rail partially just inside the sill
usually localised to floorpan though
Sun Jun 12, 2005 2:29 pm
Karan wrote: ...dunno bout the sills as thse are visible everyday so i dunno if perfect finish could be acheived
Fit the side skirts from a SE or a touring to cover up the repair work.
kevin316i
Mon Jun 13, 2005 11:40 pm
Thanks guys, appreciate the feedback.
Checking the ETK, there are replacement sills available for the E30, but the rear sill sections seem to be part of the rear quarter panel. I know a place where I can get good clean E30 sections, so I guess I should discuss the options you guys have mentioned with a local bodyshop to see what they think.
This car is going to cost alot to get right :cry:
paulj
Mon Jun 13, 2005 11:49 pm
where you from kevin, just had all my sills done by a local garage they done them for free. Guy said it wasnt a very big job to do them and you should be alright as long as you need no welding done as mine was only the rust and a re spray with some stuff to stop them rusting could get a price for you tomorrow if it helps :D
