Page 1 of 2
My Youtube Channel - BAD E30 - Restoration of my S38 Swapped E30 Touring and more!
Posted: Tue Apr 13, 2021 8:52 am
by lellis
Hi, and welcome to my Youtube Channel thread. I have recently started to produce videos of my restoration processes, which go into great depth to help people understand and learn from it.
Please have a watch if you're interested! I'll post my current videos now, then update with new ones as and when. There is much more to come, Thanks!
Re: My Youtube Channel - BAD E30 - Restoration of my S38 Swapped E30 Touring and more!
Posted: Tue Apr 13, 2021 8:53 am
by lellis
For the people asking about how I restore my hardware using zinc plating,
This video is an in depth explanation of the whole process which I find invaluable to a restoration project.
I look to use this process during every single project, having my own kit in my workshop makes it so helpful to do however big or small of a batch to suit my likings,
by lellis
I understand this is for an e34 m5 engine, however these s38 ITB's are very similar to the s14 ITB's in the e30 m3.
This is a step by step video on the complete restoration of an s38b36 individual throttle body set.
All this work was carried out by myself with only a few new wear parts that have been replaced!
Posted: Tue Apr 13, 2021 8:54 am
by lellis
Here is the complete restoration of my s38b36 air intake, unfortunatly due to size restraints of the e30 engine bay compared to the e34, there is no room for this without modification which I did not want to do. This item is now for sale!
Posted: Tue Apr 13, 2021 8:56 am
by lellis
Here's a simple video of the disassembly of my front subframe, I will be breaking the restoration down into sub-categories to go into depth of each process!
Posted: Tue Apr 13, 2021 8:57 am
by lellis
One of my favorites, this video is of my complete restoration of a s38 alternator! Some real zinc plating bling here
Posted: Tue Apr 13, 2021 8:59 am
by lellis
As always, here is the youtube video! This is a in-depth step by step video of a complete restoration of the purple tag rack, this can be used on many other e46 and similar racks!
I made this video due to the lack of information around to help complete this task.
by lellis
Here is how I restored my s38/m30 starter motor!
With no real research into the work required before starting, I was happy with how the restoration went.
by lellis
Decided to spend my weekend giving my daily a complete interior make-over!
Very happy with the end result after a lot of work, here is a video of the whole process!
Posted: Tue Apr 13, 2021 9:00 am
by lellis
Took a break over 'winter' but back to it already! Here is my latest project.
Restoration and reinforcement of my subframe.
Posted: Tue Apr 13, 2021 9:01 am
by lellis
Continuing with my front assembly restoration, here is my front control arms.
I pressed out the old ball joints and bushes, sand blasted the arms and painted with POR15, the installed LEmforder inner and out ball joints with a powerflex poly lollipop bush. Enjoy!
Posted: Tue Apr 13, 2021 9:02 am
by lellis
Now this restoration is pretty niche, but once again, with no information on how to do the process I thought I'd film the process!
Posted: Sun May 09, 2021 4:16 pm
by lellis
For anyone who has damaged or worn out fog lights that need replacing, here’s how I refurbished mine!
Not everyone wants to use cheap depo replacements.
The video includes everything needed to help do it yourself, thanks!
Posted: Tue May 18, 2021 11:22 pm
by lellis
Here is a nice detailed video of my front strut upgrade and restoration to BC coilovers and Willwood brakes!
Plus the usual POR15 goodness, obvs..
Posted: Mon May 09, 2022 7:40 pm
by lellis
I have had a lot of interest in how I have done my underseal removal, here is the video explaining each step!
Please have a watch, I hope you enjoy it.
Posted: Mon May 09, 2022 8:13 pm
by fixedwheelnut
Epic build Liam, this is going to be the dogs danglies when it is finished :D :clap: :clap:
Posted: Fri May 13, 2022 9:42 am
by lellis
Thanks Steve, I feel like I can see the end of the tunnel! Even though it looks like I am the furthest away from it..
Posted: Mon May 23, 2022 4:24 pm
by lellis
A quick video of my rear subframe restoration + reinforcement.
Using camber/toe adjustment, diff reinforcing and poly bushes!
Posted: Tue Jun 07, 2022 9:12 am
by lellis
The second part of my rear assembly series.
These original calipers were in the usual sorry state, but I have been able to get them looking fresher than out the factory
Posted: Mon Jun 20, 2022 9:58 pm
by lellis
The 3rd video to my rear assembly restoration series
The driveshafts have been a great project and a good learning curve for me.
I struggled to find much information about how to remove the axle side CV joint but there was an old thread on here which showed it was possible so I gave it a go. It turned out great and I would highly recommend others to attempt the same.
Posted: Tue Apr 11, 2023 4:13 pm
by lellis
A complete restoration of my 188mm limited slip diff video just posted on my YouTube!
This one is particularly special being a 3.15 from a z3 with extra clutch plates.
All parts and specs posted in the description for anyone interested in doing the same.
Posted: Sun Jul 23, 2023 7:03 pm
by lellis
Restoration and reinforcing of my rear trailing arms.
Posted: Sun Jul 23, 2023 7:04 pm
by lellis
Rear valance replacement including repairing all the other rust in the area (rear pockets, chassis rails etc)
Posted: Mon Aug 21, 2023 5:51 pm
by lellis
My version of the twin ear diff mounts from the e36.
Posted: Sat Oct 21, 2023 10:10 pm
by lellis
My complete underseal application process, all links to products used in the description of the video.
Posted: Mon Jan 22, 2024 5:30 pm
by lellis
My fuel system restoration and installation.
Including modifiying my vapour tank venting!
All part numbers/products used in the video description.
Posted: Thu Jan 25, 2024 5:05 pm
by lellis
The car is back on the floor!
All parts installed in this vid from 2 years worth of restoration.
Posted: Tue Aug 13, 2024 10:03 am
by lellis
My simple method to removing the sound deadening and prep for the interior respray
Posted: Tue Aug 13, 2024 10:04 am
by lellis
The DIY interior respray!
Posted: Tue Aug 13, 2024 10:08 am
by lellis
The dampening of road/drivetrain noise was a must for me. I decided to go for more than the factory, especially around the bulkhead as I don't want to install the water trap engine bay insulation.
by lellis
Something that is often overlooked during a restoration, I wanted to have a look inside and I am glad I did
Posted: Tue Aug 13, 2024 10:12 am
by lellis
I have always wanted to do the removable core/radiator support. Mainly due to the ease of access due to the size of the engine going in. I never liked the way some others did it, so I spent more time making it how I wanted.
Posted: Mon Dec 09, 2024 9:36 am
by lellis
A pretty significant update regarding the engine, it is back from the machine shop and ready for mocking up and starting the test fitting.
Posted: Tue Apr 22, 2025 7:39 pm
by lellis
Just some of the work that has been done to get the engine to fit
Posted: Tue Apr 22, 2025 7:40 pm
by lellis
Everything I have done to complete my full dry mock up
