VRD\\ Eibach and Bilstein (a match made in heaven?)
Posted: Sun Dec 27, 2020 6:50 pm
by rix313
We get asked by customers how they can rectify the sometimes very random handle characteristics of their beloved cars. The first thing we always recommend is Eibach springs and Bilstein dampers. They really are a match made in heaven. Over the years it can often be any-bodies guess as to what has been swapped and fitted. As an example we had a 325i tech 2 sport come in, the rear had an unbranded lowering spring and a standard length damper with no pressure left. On the front was a standard spring with a short travel damper. Naturally it was all over the show, the customer now reports it is like a totally different car.
Eibach
30mm drop pro-line spring kit which really doesn't alter the look of the car too drastically. It marginally improves the stance without being obvious and offer a really good ride.
  • Price for these springs is £150 delivered for 316i to 325i
  • 325i SPORT models are £215
  • Adjustable anti roll bar kits for ANY model. These brilliant kits offer three adjuster holes per side to fine tune their performance for your driving. They also come with all the fixings and brackets to easily convert a car which originally didn't have a rear ARB! £350 delivered in the UK.
Bilstein
  • B4 dampers are the OEM spec replacement damper and go really well with this spring set up.
  • For lower or sportier applications there are the B6 and B8 damper options.
  • finally the B12 spring and damper kit uses an Eibach spring kit with a B8 sport damper for a great fast road set up.
  • POA
Re: VRD\\ Eibach and Bilstein (a match made in heaven?)
Posted: Mon Dec 28, 2020 10:48 pm
by fixedwheelnut
Have you got a link to the anti roll bar kits please?
Posted: Wed Dec 30, 2020 6:41 pm
by rix313
Hi! I have an advert in the for sale section on the forum. Or if you'd like some more information send me a PM and I'll happily talk through the kit :D
