MOT Day....
Posted: Sat Mar 15, 2008 8:42 am
by capri_rob
11am - wish me luck !
Re: MOT Day....
Posted: Sat Mar 15, 2008 10:48 am
by wackiacki
good luck mate hope all goes well
Re: MOT Day....
Posted: Sat Mar 15, 2008 2:17 pm
by stevotheevo
did it pass then mate.
Re: MOT Day....
Posted: Sat Mar 15, 2008 3:16 pm
by capri_rob
Failed - but then I was kind of expecting it - not on much though !
Failed on : n/s headlamp aim too high
V small hole at end of sill on n/s - needs patch welding about 1" square
Drop link bushes to rear axle worn
Plus advisories on both rear radius arm bushes worn but not too bad.
So all in all it failed on fairly standard old car stuff !
Booked in for Wednesday to sort it - shouldnt be too expensive either.
Underneath looks very solid - no leaks from engine or transmission at all.
Re: MOT Day....
Posted: Sat Mar 15, 2008 3:40 pm
by stevotheevo
ah well, no too bad mate.
Re: MOT Day....
Posted: Sat Mar 15, 2008 5:10 pm
by wackiacki
doesent sound too bad,a small victory i suppose.from experience,if thats all the failiure and advisory items youve got yourself a pretty sound e30 there.just expect welding to get bigger,always does when grinding down to find clean metal to weld to.did he not find hole in your n/s/f inner wing?
Re: MOT Day....
Posted: Sat Mar 15, 2008 5:38 pm
by capri_rob
wackiacki wrote:doesent sound too bad,a small victory i suppose.from experience,if thats all the failiure and advisory items youve got yourself a pretty sound e30 there.just expect welding to get bigger,always does when grinding down to find clean metal to weld to.did he not find hole in your n/s/f inner wing?
If he did he didn't comment on it and I certainly wasnt going to point it out !
Was quite suprised at how thorough the test is now - especially the checks for corrosion - the bit he failed it on I hadnt even noticed and he seemed to spend ages tapping away at the sills/underside with the little hammer trying to find crusty bits !
Will get it through the MOT first and then worry about it when I do the bodywork blitz.
Re: MOT Day....
Posted: Sat Mar 15, 2008 6:30 pm
by wackiacki
hopefully he dident spend too long tapping.corrosion is to be assesed in 3 ways. 1.visual 2.finger and thum pressure and 3.corrosion assesment tool.(little hammer). the test is now so thorough because modern cars have become more complicated.sill looks like he gave her a good going over for ya,least you knw shes sound.bring on the rain!!!
Re: MOT Day....
Posted: Sat Mar 15, 2008 6:45 pm
by agreen
I think for old cars these things have to be expected dont they ,
Hope you get it sorted for cheap enough fella .
Re: MOT Day....
Posted: Sat Mar 15, 2008 11:51 pm
by capri_rob
wackiacki wrote:hopefully he dident spend too long tapping.corrosion is to be assesed in 3 ways. 1.visual 2.finger and thum pressure and 3.corrosion assesment tool.(little hammer). the test is now so thorough because modern cars have become more complicated.sill looks like he gave her a good going over for ya,least you knw shes sound.bring on the rain!!!
He spent ages tapping away with the "corrosion assessment tool" !
Suprisingly he didnt find much - and I suppose MOT failure on knackered rubber bushes goes with the territory on a 21 Year old car.
Oh well - it will have 12 months ticket on it by this time next week and I'll be a few quid lighter....again
Re: MOT Day....
Posted: Sun Mar 16, 2008 5:52 pm
by capri_rob
Welding required .....
Should I be asking the garage to fit poly-bushes instead of the standard rubber ones ?
Is there much difference in cost / handling when its done ?
Re: MOT Day....
Posted: Sun Mar 16, 2008 6:27 pm
by wackiacki
if there rear anti-roll bar drop link bushes,polyurethane ones are only a benefit if you completely replace all the bushes with them.but if thats what your planning to do its a good place to start.and i suppose it wouldent hurt.wouldent ask the garage to supply them though,might get stung on cost.
i have a guy that sometimes does some heavy work i cant do myself and if i get the parts first he does it for cash,bit cheaper.woth an ask!!
Re: MOT Day....
Posted: Sun Mar 16, 2008 7:49 pm
by Brianmoooore
agreen wrote:I think for old cars these things have to be expected dont they ,
Never had an MOT failure, and the only advisory I can remember was for tyre tread (or rather lack of it). This is what I expect from a car with a BMW badge on it!
Re: MOT Day....
Posted: Sun Mar 16, 2008 7:53 pm
by Brianmoooore
capri_rob wrote:Should I be asking the garage to fit poly-bushes instead of the standard rubber ones ?
Don't even consider it on a car that is ever used on the road. Leave the nasty aftermarket stuff to the Nova/Corsa/Saxo brigade.
Use genuine BMW bushes, with E30 M3 control arm bushes at the front, and E46 cab top damper mounts at the rear.
Re: MOT Day....
Posted: Fri Mar 21, 2008 3:16 pm
by capri_rob
WOOHOO ! - Now have 12 months MOT !
£131.50 all the work and partial re-test. Quite happy with that !
Re: MOT Day....
Posted: Fri Mar 21, 2008 3:25 pm
by wackiacki
