Page 1 of 2
ITB air filters
Posted: Tue Feb 19, 2008 6:55 pm
by oakey
Can anyone tell me the benefits of a 'sausage' filter- (
http://www.itgairfilters.com/downloads/JC100.pdf) compared to 'sock' filters?
I cant see how there can be much difference in them for performance reasons.
I dont imagine I will be setting the sock filters on fire as I'm not going to running a mentally high lift cam and the fuelling should be spot on after Ant's worked his magic.
Help please
. Obviously sock filters will save me a fair bit of wongar
Re: ITB air filters
Posted: Tue Feb 19, 2008 9:09 pm
by oakey
bumpy
Re: ITB air filters
Posted: Tue Feb 19, 2008 9:16 pm
by maxfield
I've heard sausage filters are better than sock filters.
I would of guessed the sausage has more surface area.
Re: ITB air filters
Posted: Tue Feb 19, 2008 10:09 pm
by oakey
maxfield wrote:I've heard sausage filters are better than sock filters.
Probably, but not necessarily. I cant be bothered to work it out.
I have been told they are aswell and I believe it but I thought it was mainly due to the the fact that socks can set alight
I think for the time bieng I will use them unless anyone has any reasons not to
Re: ITB air filters
Posted: Tue Feb 19, 2008 11:00 pm
by 1an
persoanlly i would use 'socks' as i think they will look better
Re: ITB air filters
Posted: Wed Feb 20, 2008 1:26 am
by Jhonno
There is a Vaux tuner who warns against using socks due to them losing power when compared to sausage filters.. iirc it was quite a high figure, albeit on a v highly tuned lump..
Re: ITB air filters
Posted: Wed Feb 20, 2008 1:28 am
by Jhonno
1an wrote:persoanlly i would use 'socks' as i think they will look better
Re: ITB air filters
Posted: Wed Feb 20, 2008 3:20 am
by oze30
Shall we start a thread as to why this is wrong???
Re: ITB air filters
Posted: Wed Feb 20, 2008 8:27 am
by oakey
Jhonno wrote:There is a Vaux tuner who warns against using socks due to them losing power when compared to sausage filters.. iirc it was quite a high figure, albeit on a v highly tuned lump..
Why would you loose power with them though compared to a sausage as they will both suck in alot of hot air
The only difference is that the with the sausage there is no filter foam touching the trumpets where as the socks are pressed against the trumpets. I suppose this may affect the amount of air the trumpet can intake?
Re: ITB air filters
Posted: Wed Feb 20, 2008 8:54 am
by oakey
oze30 wrote:1an wrote:persoanlly i would use 'socks' as i think they will look better
Poor 1an
I think he deserves a medal and a cookie for the amount of stick he gets
Re: ITB air filters
Posted: Wed Feb 20, 2008 9:30 am
by d6dph
He deserves a beating with a shitty stick some days.
Ian, Think before speaking
Re: ITB air filters
Posted: Wed Feb 20, 2008 11:07 am
by Jhonno
oakey wrote:Jhonno wrote:There is a Vaux tuner who warns against using socks due to them losing power when compared to sausage filters.. iirc it was quite a high figure, albeit on a v highly tuned lump..
it must be related to the how they sit with the trumpets and how they affect the airflow
i'm only relaying what ive found out previously.. they actually had it as a page on their site
Important Notes
Read below before you waste all the BHP you have spent lots of hard earned money on achieving & throw it away on the intake system.
1. Never use Ram pipe sock filters of any type, you will lose between 20 to 60 BHP.
Re: ITB air filters
Posted: Wed Feb 20, 2008 11:08 am
by Jhonno
d6dph wrote:He deserves a beating with a shitty stick some days.
Re: ITB air filters
Posted: Wed Feb 20, 2008 5:55 pm
by oakey
Thanks for the info Jhonno.
I'm going to go for socks for the time being, as I'm poor
Then when I get it dynoed, if it doesnt produce as much power as I'd like, I will upgrade to a sausage.
Re: ITB air filters
by oakey
Any chance of a link to the site you are quoting Jhonno?
Re: ITB air filters
Posted: Thu Feb 21, 2008 2:22 pm
by oakey
Trumpets and socks ordered
Should arrive monday so I'll update with some piccies.
For the record-
Sock filters are poo because they are touching the trumpets there fore restrict the airflow.
So as soon as its all fitted I will fit an itg sausage filter or a plenum. I dont want to go splashing out on anything expensive now incase it doesnt fit! lol
Re: ITB air filters
Posted: Thu Feb 21, 2008 4:08 pm
by jimthejunior
Personaly i wouldn't run anything. Only in the winter or mega shitty weather would i run somekind of itg filter, over them.
I know loads of people who run them open and have no problems in good weather.
Re: ITB air filters
Posted: Thu Feb 21, 2008 6:30 pm
by oakey
jimthejunior wrote:Personaly i wouldn't run anything. Only in the winter or mega shitty weather would i run somekind of itg filter, over them.
I would like my engine to last more than 6months. lol
Re: ITB air filters
Posted: Thu Feb 21, 2008 6:49 pm
by jimthejunior
oakey wrote:jimthejunior wrote:Personaly i wouldn't run anything. Only in the winter or mega shitty weather would i run somekind of itg filter, over them.
So does that mean you have already ran a itb'd car without filters and the engine died six months later?
Or it that what you "think" will happen. Using your past experience running this said set-up.
Re: ITB air filters
Posted: Thu Feb 21, 2008 6:51 pm
by snoops
sounds good, whats the expected completion date for everything?
Re: ITB air filters
Posted: Thu Feb 21, 2008 7:02 pm
by oakey
jimthejunior wrote:oakey wrote:jimthejunior wrote:Personaly i wouldn't run anything. Only in the winter or mega shitty weather would i run somekind of itg filter, over them.
Dont take me so seriously pal
I have never driven a car with open itb's. But from speaking to people with knowledge (I'm not saying you dont) sock filters do not filter the air as well as needed, so how can running them open be a great idea?
This is all for a road car btw so it will be getting driven reguarly.
Surely you understand that running open tbs is a risk.
@ Snoops. Its been put back a week from going to Ant's place. So next week it will be getting started and it shouldnt take too long hopefully
So to answer your question- soon
I'll be happy with anything 230hp+ with plenty of torque
Re: ITB air filters
Posted: Thu Feb 21, 2008 7:08 pm
by lenny-d
take it it's a 2.7 then
Re: ITB air filters
Posted: Thu Feb 21, 2008 7:10 pm
by oakey
^ correcto
Re: ITB air filters
Posted: Thu Feb 21, 2008 7:18 pm
by Jhonno
oakey wrote:Any chance of a link to the site you are quoting Jhonno?
www.sbdev.co.uk
um.. why buy twice Dave? Seems a little odd to me.. How much cheaper are the socks? Dont settle for 2nd best, esp when a swap of filter could see the power your engine should be making!
This lump going to have a worked head btw?
Re: ITB air filters
Posted: Thu Feb 21, 2008 7:29 pm
by oakey
Jhonno wrote:oakey wrote:Any chance of a link to the site you are quoting Jhonno?
www.sbdev.co.uk
Just a new cam and springs. Head allready gas flowed.
Socks are £10 each. Sausage filter £200+vat + backplate £50+ vat.
You're allways suspicious Jhonno. lol.
Basically I dont know exactly where the sausage filter will situate so I dont want to splash out on one until the itbs are all fitted.
The sausage filter from itg looks fantastic and it seems perfect for my application it it fits.
I can dyno it with socks and then with open tb's and see the power difference.
Re: ITB air filters
Posted: Thu Feb 21, 2008 7:33 pm
by jimthejunior
My technical knoledge(sp) of tuning isnt on par with the likes of ant, and its just common sense that dirt getting inside engines isnt a good thing. But personal experience, and seeing a lot of people i know running them open leads me to my suggestion that i made earlier. Hence why i also said shitty weather and winter id run filters/socks whatever. ANd damn right its a risk.
Anyway, high powered itb'd cars rock. The sound of open itb's on a "normal" engine is probably the 2nd best sound i can think of to do with cars.
Re: ITB air filters
Posted: Thu Feb 21, 2008 11:19 pm
by lance1a
Not ITB's, but similar setup. I ran socks on 110 x 50mm trumpets (with 2 " free on top of trumpet), seemed ok, changed for RC125 Maxiflow filters, made more revs, less torque. Now use narrow (36mm x 130mm) trumpets with and without socks (now with all the crap on the roads I use socks). Though I want to make up a plenum to feed cold air to the carbs
as I notice a distinct difference if sucking too much warm air. Pipercross do a sealed airbox for ITB/multicarb setups.
Re: ITB air filters
Posted: Fri Feb 22, 2008 1:08 am
by oakey
^ Yeah I have seen the pipercross ones but they dont do a filter the correct size for either all six trumpets or 2 filters for 3 trumpets each
Re: ITB air filters
Posted: Fri Feb 22, 2008 7:47 am
by lance1a
Ah, sorry, I didn't read too well...a six pot! You could get one made up, but it won't be cheap I suppose.
For the airbox I want to make for mine I am using a home made (as is everything else on my car) plate attached to the TB's/carbs themselves, and an alloy tube, cut to fit the plate and blanked at one end.....with enough depth to leave the stacks in place inside the plenum. Essentially it will look like the Pipercross one...but a bit more DIY'ish, coz I'm skint as usual.
Re: ITB air filters
Posted: Fri Feb 22, 2008 12:35 pm
by Jhonno
oakey wrote:^ Yeah I have seen the pipercross ones but they dont do a filter the correct size for either all six trumpets or 2 filters for 3 trumpets each
What about 3 x 2?
Best bet is still the all in one sausage imo
Re: ITB air filters
Posted: Fri Feb 22, 2008 12:39 pm
by Jhonno
oakey wrote:Just a new cam and springs. Head allready gas flowed.
Who me?!
I'd be interested to see comparative dyno's open/socks/sausage - Be intriguing to see the effect on a fairly tuned M20, maps would need tweaking for each tho..
Checked ebay for any sausage filter bargains maybe?
regardless of all the above.. Get the tb's on there like yesterday i wanna hear it
Re: ITB air filters
Posted: Fri Feb 22, 2008 1:01 pm
by oakey
Should be on there in no more than 2 weeks
I'm excited!
Socks just make things so much simpler at this stage.
Re: ITB air filters
Posted: Fri Feb 22, 2008 1:33 pm
by agreen
Now i know this is not realy the topic of the thread but , all this talk about what filters to use on itb's and the power diffrences , butwhat about the acctual trumpet diameter and lenth ? how is this done i have itb;s to put on my m42 but am unsure about this
surley incorrect lenth trumpets would also affect the power ?
Re: ITB air filters
Posted: Fri Feb 22, 2008 2:23 pm
by Jhonno
there isnt really such thing as incorrect trumpet length.. however length affects the power delivery of the engine
longer trumpets offer a little more mid range, shorter more top end as a general rule..
trumpet diameter is dictated by the size of the tb's used
Re: ITB air filters
Posted: Fri Feb 22, 2008 2:34 pm
by oakey
I'm using 38mm tbs (which is quite small) with long runners therefore I should keep a fair bit of midrange. I have found lots of info of how to calculate where you get peak power, but I cant find any of the sites now
With engines like the m20/m42 its probably a matter of trial and error to get the lengths perfect.
