Clutch bearing
Posted: Sat Sep 22, 2007 4:53 pm
by Spankie
Hi just wondered if all new bearings are plastic, I've bought a LUK clutch kit for my 325i which seems identical to original BMW kit fitted to my car except the bearing. The original one looks chunky is all metal and really well made, the new one has a really thin metal bearing face and is part plastic it does look strong at all as a matter of fact it looks....er....shite!
I'm half tempted to stick the old one back in!!!
Looking for reassurance hear please :roll:
Re: Clutch bearing
Posted: Sat Sep 22, 2007 7:49 pm
by Templ8e30
Even new BMW clutch release bearings are plastic.
Make sure the guide tube is free from oil and grease before you fit the bearing, the plastic wears quickly with oil and grease present.
Cheers,
Iain T
Re: Clutch bearing
Posted: Sat Sep 22, 2007 8:04 pm
by Spankie
Iain
Thanks, I'm just about to put it back together so timely advice.
Other thing i noticed is how slack a fit bearing is on guide tube, so its hardly gonna stick!
Thanks again.
Re: Clutch bearing
Posted: Sun Sep 23, 2007 11:04 pm
by kipper
another reason to make sure its free from any oils or graese's is these can end up on the clutch plate and then burn on to it and cause slipping.. :cry:
Posted: Sun Sep 23, 2007 11:20 pm
by Martinaston
I think the reason they wear out is because there shit, the bearings not even centred on the guide :mad:
I'll see how long it lasts before it falls apart :roll:
Re:
Posted: Sun Sep 23, 2007 11:27 pm
by Martinaston
Or is the right hand side the top ?
Re:
Posted: Mon Sep 24, 2007 11:30 am
by Spankie
Dont worry about the center ofset, the original bearing is the same, the inner sleve is design to move within bearing, its quite stiff but you can re- centre it by hand if you want I guess idea is under pressure it will self centre.
Cheers.
Re:
Posted: Mon Sep 24, 2007 1:06 pm
by Martinaston
I hope its not too stiff, i've already put it in. ooh err
