Engine Died Today!!!!!
Posted: Wed Sep 19, 2007 11:57 am
by Pal318is
Guys,
While driving home yesterday from work, the engine started to leak water very badly :( the tempreture went all the way to the red and steam was billowing from under the bonnet. I parked the car up and let it cool down. I intially thought that the leak was coming from a rubber hose that had split. But upon inspection today, it's much worse than first thought!!
There is a small metal gromet type pipe that is part of the block (it sits at the back of the engine) on this gromet goes a rubber hose. Well the metal pipe has corroded completely, so in turn the rubber hose has nothing to go on to.
I'm totally gutted :cry: :cry: as I now have no car...
I have another engine and box sitting at home, but have been lazy sorting it out :roll: I've got no car for about 3-4 weeks now, I do have someone who is going to fit the new engine, for £180, but he's stacked to the ceiling, with work....
Has this happened to anyone else??
My mate has a e46 318i and the same thing happened to him. BMW told him, he would need a new engine, but he got it fixed, from his mates garage. I think they welded on a new pipe 8O
Sorry if I sound like i'm ranting Guys...Oh well the engine has done me proud, all 215K :)
Pal
Re: Engine Died Today!!!!!
Posted: Wed Sep 19, 2007 12:29 pm
by Angus325e
never happened to me or ne1 that i know of, but surely some nifty work with the welder can get her up and running! seems like such a little thin to cause such a big problem. is the lump ok other than this?
Posted: Wed Sep 19, 2007 12:34 pm
by Pal318is
The lumps fine, I did think about getting it welded, but it's still a bit of a job! I would give it a go myself, but have never used a welding machine before :cry:
Pal
Posted: Wed Sep 19, 2007 12:55 pm
by Kedge
Arh bugger!!!
Not heard of that happening before mate, i'd be a little worried that it may of cooked something else if the tempterature shot it. As i started reading i was expecting you to say your profile gasket had gone.
If you can use a spanner it a pretty easy job to change an M42 mate, i had mine out in 2hours and i'm not the best when it come to that kind of thing.
Posted: Wed Sep 19, 2007 2:07 pm
by ric325i
dude one of my pipes split on my m30 conversion and it may have cooked the engine? but i know how you feel with the bonnet open and water everywhere.
dude do you have tools? rent a engine lift and do it yourself. its not that hard!
dont know how to split gearbox from engine but get that done, disconnect exhaust, undo engine mounts, disconnect rad, and unclip wire connector and you should be able to lift the engine out!
its not mega easy but it can be done by use driveway people. some people can do it ina few hours. but plan a weekend for a 1st timer and any porblems.
good luck :D
Posted: Wed Sep 19, 2007 2:09 pm
by Kedge
Splitting the gearbox is easy, getting it back together is a pain though!
Posted: Wed Sep 19, 2007 2:17 pm
by agreen
sorry dude hope it gets well soon
Posted: Wed Sep 19, 2007 2:25 pm
by tim_s
er pal do you mean the one at the back of the cyl head? That's the one that usually corrodes. There's not one poking out of the block. If it's the head one, its not the most difficult thing to do the cyl head, though with the miles yours has done might be worth swapping the engine. other options include tapping the hole and screwing in a brass fitting or something, the tricky bit would be finding an appropriate fitting.
Posted: Wed Sep 19, 2007 4:05 pm
by bryang
Sorry to heat that mate, you did say the other week you was going to put the “new “ lump in it!
If its any consolation I came out to my car this morning and had no clutch so im badgering everyone for lifts to work at the mo as well!
Hope you get it sorted soon
Posted: Wed Sep 19, 2007 11:37 pm
by Pal318is
tim_s wrote:er pal do you mean the one at the back of the cyl head? That's the one that usually corrodes. There's not one poking out of the block. If it's the head one, its not the most difficult thing to do the cyl head, though with the miles yours has done might be worth swapping the engine. other options include tapping the hole and screwing in a brass fitting or something, the tricky bit would be finding an appropriate fitting.
That's the one Tim, I do know of someone who can fix it for me, but tbh with the extra costs of doing this, it's just not worth it.
Tbh i'm just going to get the 'new' lump dropped in, within the next month, with some new bit's. Timing chain, hoses, gasket's and the like. I'd like a JB flywheel too, but will hopefully get one, when the clutch is on it's way out, due to the wait kedge had for his (1 month :cry: )
Mot's ain't due till end of November, so would like all things in place before then. Fingers X
Bryan,
My getting a lift to work skills are needed again mate! hate not having the car :cry:
Funnily enough tho, one of my mates at work, offered to lend me his car, after we finish work..Top Man...even if it is a e46 :)
Pal
Posted: Wed Sep 19, 2007 11:44 pm
by 325bhpbruiser
would say i'd get it in my place for yer but would wanna work on it incase i done any damage, your car looks mint.
i do have mig welder you can borrow if yer fancy a shot at welding the pipe if yer want?
Posted: Wed Sep 19, 2007 11:51 pm
by Kedge
Pal i only had to wait for so long as the UK supplier had no stock and was waiting for JBR to get a btach made. You maybe lucky and they have one in stock when you want it.
Posted: Thu Sep 20, 2007 12:04 am
by Gortour
Good luck with the repairs Pal.
Hope you're still able to get to the Pod this weekend...
Posted: Thu Sep 20, 2007 7:32 am
by Pal318is
Guys,
Thanks for all the offers, really appreciate it :)
Bruiser, cheers mate, but i'm just going to get the other lump in there now. Too much hassle to fix it now...
Kedge, thanks for the info mate, i'm going to look into this more.
Gordon, thh mate, i'm not coming to the Pod now :( my brother and a few friends will be there, but with the car in that state it is and my son having a Cup game on Sunday too, it's a no brainer now :cry: :cry: :cry:
Oh well, i'll be back, hopefully bigger and better 8) 8)
Pal
Posted: Thu Sep 20, 2007 10:11 am
by Kedge
Make sure you order the clutch kit at the same time as the flywheel if you do go down that route.
Shame your not going to make the pod, what about Stoneleigh in Oct? You might want to actually see what difference the flywheel makes as i'm doing it blind really.
Posted: Thu Sep 20, 2007 10:45 am
by Pal318is
All the feedback from this has been good tbh. So I firmly believe that it will be the 'bollox' :D
If/when I do, do this, I will make sure I get the clutch kit too. What date is the Stoneleigh bash?? If your going, I can check your's out winkeye
Pal
Posted: Thu Sep 20, 2007 10:56 am
by pnd
215k from an is thats got to be a record new engine is the way forward.
Posted: Thu Sep 20, 2007 11:05 am
by Kedge
Its on Oct 14th.
Yea you can see what it is like mate no problem.
Posted: Thu Sep 20, 2007 11:42 am
by Pal318is
Cheers Dave :cool:
Pal
Posted: Thu Sep 20, 2007 3:36 pm
by 325bhpbruiser
no worries pal, if ever your stuck for somthing like that am only in westderby if yer wanna give me a shout. :cool:
Posted: Thu Sep 20, 2007 4:45 pm
by Pal318is
Top man ^^
Pal
