320 with 325 throttle and chipped ecu
Posted: Sat Sep 15, 2007 1:17 pm
by dannyboy759
Just installed a 325i throttle into my 320 touring and a spare ecu that I had with an active autowerke chip in it.
Its made hell of a difference to the trottle response and the torque of the car.
Not sure if its done any power increase but it goes well.
I might try changing the inlet manifold to as the one on the car is the standard 320 one and then change the injectors.
Re: 320 with 325 throttle and chipped ecu
Posted: Sat Sep 15, 2007 1:54 pm
by cypriot_boy_2k7
y not just get a 2.5 drop er in
Posted: Sat Sep 15, 2007 6:26 pm
by StuBeeDoo
dannyboy759 wrote:I might try changing the inlet manifold to as the one on the car is the standard 320 one and then change the injectors.
Mate, don't change the injectors!
Personally, I wouldn't use the 325i manifold either, but that's open to debate.
When I did mine, all I did was open out the mouth of the 320i manifold (making sure there is enough "lip" for an air-tight seal) and fit a "wild" chip. I've never had the car on rollers, but it's definitely far better than standard.
Posted: Sat Sep 15, 2007 6:50 pm
by ed325i
Why not :?:
Posted: Sat Sep 15, 2007 7:46 pm
by StuBeeDoo
Why not :?:
I'm a mid-range man Ed. The bigger runners in the 325i manifold will be better for top-end but at the expense of mid-range - which the B20 is already sadly lacking because the standard runners and ports are too big.
Like I said, it's a personal thing.
Posted: Sat Sep 15, 2007 8:39 pm
by ed325i
What about using the eta inlet :?:
Posted: Sat Sep 15, 2007 9:16 pm
by dannyboy759
Yeah get you with the inlet manifold thing, it works fine as it is and to be honest the extra grunt is where it should be.
I mean I took it out today adn i had two adults and two kids in the car with a boot full of stuff and a full tank of full and the thing just pulls from as low as 2000rpm perhaps even a little lower.
So why wouldnt i want to run 325 injectors?
Seems right thing to do if im running a 325 ecu and a chipped one at that.
And whats the difference between a 325e manifold and a 325i manifold i know the 320 the intake holde is smaller but it lists the eta part as a completely different number to either the 325 or the 320.
Posted: Sun Sep 16, 2007 9:52 am
by StuBeeDoo
dannyboy759 wrote:So why wouldnt i want to run 325 injectors?
325i injectors will flow too much and cause over-fueling. The 320i injectors are capable of flowing enough for a 2.3 engine, so they will be good enough for your engine.
It doesn't matter what ECU you're running as long as the chip in it is the right one. You can run a 325i on a 316i ECU as long as it has a 325i chip in it. If your ECU has a 325i chip, the ignition and injection timing will be wrong.
Posted: Sun Sep 16, 2007 2:28 pm
by ed325i
The eta inlet has small ports like the 320 one but has longer runners, giving more low down power like the eta.
Posted: Sun Sep 16, 2007 2:41 pm
by Andyboy
No it doesn't! The Eta head uses the tiny ports from the old E21 320 and 323i heads. That won't be any good at all.
I would use a 325i manifold as it just makes it a tidier job.
Posted: Sun Sep 16, 2007 2:54 pm
by ed325i
Best not use the eta one then.
Posted: Sun Sep 16, 2007 7:53 pm
by oze30
??? Isn't the low down power being caused by the fact it's:
a) 2.7 and
b)it's a 2.7???
Oh.. forgot
c) It's built as a torquey engine rather than top end hence having a 5-6k redline.
Posted: Tue Sep 18, 2007 6:36 pm
by diamondblacke28
i used m50b20 520i injectors in my 325i the spek figures of them are slighty higher than the m20b25 ones.
and there is some improvement in my 325i i think it down to the better spray pattern and fanning out for the fuel.
Posted: Tue Sep 18, 2007 7:49 pm
by ed325i
a) 2.7 and
b)it's a 2.7???
Oh.. forgot
Yes but inlet design has alot to do with it to >> http://www.e30zone.net/modules.php?name ... =eta+inlet
