The good oil
Posted: Fri Aug 31, 2007 1:08 am
by tassiedevil
Just managed to get my hands on nice low mileage M3 and am wondering what oil is best used in the S14 motor.
Re: The good oil
Posted: Fri Aug 31, 2007 10:47 am
by ed325i
Ask the oil man here >> http://www.opieoils.co.uk/
Re: The good oil
Posted: Fri Aug 31, 2007 10:50 am
by dannyboy759
Not modern syntheic stuff like most people think, go for castrol mineraln oil I for get the grade now
Re: The good oil
Posted: Mon Sep 03, 2007 3:49 pm
by oilman
Disagree synthetics are ideal and make a good choice, the best are the ester based synthetics of Silkolene and Motul.
Silkolene Pro S 5w-40 has been well proven.
Guy.
Re: The good oil
Posted: Mon Sep 03, 2007 7:31 pm
by DanThe
dannyboy759 wrote:go for castrol mineraln oil
I wouldnt even lubricate my nuts with that stuff :eek:
Re: The good oil
Posted: Mon Sep 03, 2007 8:29 pm
by johnono
fpmsl :cry:
Re: The good oil
Posted: Mon Sep 03, 2007 9:52 pm
by dannyboy759
5w.40 is too thin for an engine that was designed to run on mineral, even now they run Group A cars on Castrol but agreed there are better oils out there than castrol but the basic theroey still stands its the grade that important
Re: The good oil
Posted: Mon Sep 03, 2007 10:12 pm
by orr
I have had my e30 m3 for 9 years and i put 15 /40 in it and its been fine ,castrol.
Re: The good oil
Posted: Mon Sep 03, 2007 11:16 pm
by Demlotcrew
dannyboy759 wrote:5w.40 is too thin for an engine that was designed to run on mineral, even now they run Group A cars on Castrol but agreed there are better oils out there than castrol but the basic theroey still stands its the grade that important
Not strictly true, the S14 was designed to run on fully synth and i would not use anything but 10w60 TWS or Edge (same thing) but not Edge sport.
Pro S has the same specs as castrol GTX so If you want the best then go for Castrol 10w60.
Andrew
Re: The good oil
Posted: Tue Sep 04, 2007 12:06 am
by Morat
Real men use chip fat!!!
Re: The good oil
Posted: Tue Sep 04, 2007 9:49 am
by oilman
Its not too thin at all, the recomended grade is an SAE40 when hot, either 5w 10w or 15w when cold, wich kind of works out at 5w-40 synthetic, 10w-40 semi synthetic and 15w-40 mineral. As oil is many times thicker when cold then when hot if it is ever going to be too thin it will be when hot ie using an SAE20 or SAE30.
On top of that the engine was not designed to run on mineral, its not inteligent and will not know weather you have put mineral or synthetic in it, its weather you want to protect it better by using a synthetic over a mineral.
On the flipside when most of these cars were produced mineral based were the only real available oils to the end user.
Guy.
Re: The good oil
Posted: Tue Sep 04, 2007 1:10 pm
by bryang
Guy.
So really they where designed to run on mineral by BMW and if its running good some 15 years or so later you'd have to say adding a top line fully synth oil now is a waste of money.
Re: The good oil
Posted: Tue Sep 04, 2007 3:03 pm
by oilman
Erm no... They were not designed to run on mineral oil, they were desgined to run on oil!
I was saying that if you went to halfords 15 years ago you did not have the choice of synthetics to the end user you have now (so for many years they ran on mineral as that is what haflords etc had), just like still in some countries all they have available to them is cheap mineral oils, not much good having a car if it cannot run on these? So it can run on either and the choice is yours.
Guy.
Re: The good oil
Posted: Tue Sep 04, 2007 5:08 pm
by hongkongfuey
dude when i worked at bmw all 'm' engine replacement oil was mobil one
Re: The good oil
Posted: Tue Sep 04, 2007 5:41 pm
by Simon13
ok run an S14 on mineral and see how long it stays healthy, or how much quicker it wears out compared to an engine run on decent oil
Re: The good oil
Posted: Tue Sep 04, 2007 5:54 pm
by munky30
oilman wrote:Erm no... They were not designed to run on mineral oil, they were desgined to run on oil!
I always thought they were designed to run on petrol.
Re: The good oil
Posted: Tue Sep 04, 2007 6:15 pm
by Simon13
ho ho ho
Re: The good oil
Posted: Wed Sep 05, 2007 9:21 am
by oilman
This is true, but see how far it gets with no oil in it.
Guy.
Re: The good oil
Posted: Wed Sep 05, 2007 9:51 am
by touringandy
i was also advised not to use a synthetic oil mines on 15/40 mineral an runs smooth as a whistle :wink:
Re: The good oil
Posted: Wed Sep 05, 2007 11:21 am
by oilman
Did they say why they advised that?
Guy.
Re: The good oil
Posted: Wed Sep 05, 2007 11:47 am
by Morat
synthetic > mineral.
They do the same job, but synthetic does more reliably. There are no "compatibility issues" its all oil, just synthetic oil has more of what you want, and less of what you don't.
