e46 top mounts, damned fine
Posted: Thu Aug 16, 2007 12:04 am
by thesaint
just put those e46 top mounts ojn, good, probably cos mine had fallon to peics put it wa very good and reccomend it to anyone.
Re: e46 top mounts, damned fine
Posted: Thu Aug 16, 2007 12:06 am
by Demlotcrew
From BMW?
Posted: Thu Aug 16, 2007 12:08 am
by thesaint
yes.
Re:
Posted: Thu Aug 16, 2007 12:12 am
by Greeny
Whats the difference between the e46 top mounts and the e30 ones?
Re:
Posted: Thu Aug 16, 2007 12:13 am
by sleepenvy
do they have any negative camber on them?
Re:
Posted: Thu Aug 16, 2007 12:22 am
by 320Touring
Greeny wrote:Whats the difference between the e46 top mounts and the e30 ones?
e30 ones have the metal sleeve on the rod of the damper, e46 cab oned have it moulded into the mount. less likely to part company.
firmer rubber too-well worthwhile mod!
Re:
Posted: Thu Aug 16, 2007 12:25 am
by tezk
Zimmerbimmer1 on here can supply top mounts at £22 ish. Well worth the money!
Will be £41 ish with reinforcing plates, though zedone might have a few reinforcing plates left:
http://www.e30zone.net/modules.php?name ... ic&t=71236
I have a pair to fit - look excellent quality!
Re:
Posted: Thu Aug 16, 2007 9:11 am
by ian332isport
sleepenvy wrote:do they have any negative camber on them?
Whatever you do with the rear top mounts, it won't change the rear camber. You can only change the rear camber with eccentric trailing arm bushes or a modified rear subframe.
Ian.
Re:
Posted: Thu Aug 16, 2007 9:34 am
by Bob_S
i just picked up mounts and plates for £33? gen bmw from the dealer?
