Gasket set 318is?
Ammaco
Wed Aug 15, 2007 7:28 pm
Currently have the head of my e30 318is for a bit of a look. Gona rebuild it but wanna replace most of the gaskets, just wondering if you can buy all the gaskets as a set? instead of searching for loads of part numbers? any one know? cheers
Chris-W
Wed Aug 15, 2007 8:09 pm
Head Gasket set plus head gasket is what you need.
Ammaco
Wed Aug 15, 2007 8:18 pm
I was hoping it would be tht simple! Does that include things like timing case gasket, thermostat housing gasket and exhaut manifold gaskets etc??
How much should these cost, cheers
Ammaco
Wed Aug 15, 2007 11:04 pm
bumpety
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Aug 15, 2007 11:06 pm
ecp do one for under 100quid :cool:
cliffybabe
Powered by Nelly
Powered by Nelly
ow yeah all of the gaskets u mentioned and more :)
Demlotcrew
Thu Aug 16, 2007 12:05 am
Just make sure you take the gasket set to Atech and get A to measure all the gaskets just in case they are too thick, as this will not doubt loose you about 25bhp! :wink:
oguz327
Captain Armco
Captain Armco
Thu Aug 16, 2007 12:15 am
Demlotcrew wrote:Just make sure you take the gasket set to Atech and get A to measure all the gaskets just in case they are too thick, as this will not doubt loose you about 25bhp! :wink:
OT, your as bad as each other, pick up the phone :D
josh-hocking
Teenager with Taste !
Fri Aug 17, 2007 12:27 pm
halfords can order them
Andyboy
Alpina Colada
Mon Aug 20, 2007 9:28 pm
You Biiatch!
