Meguuiars quick clay
Posted: Wed Apr 27, 2005 8:31 pm
by Simon13
Got this stuff the other day
And it does exactly what it says on the tin Ronsil stylee
Sh!t hot paint work smooth as a babys arse!
not bad for 11 quid
Posted: Wed Apr 27, 2005 8:43 pm
by Lowm3
yeh its good stuff, for best result polish and wax straight after to seal the smooth glass paintwork. :cool:
Re: Meguuiars quick clay
Posted: Wed Apr 27, 2005 10:07 pm
by Splondike
Simon13 wrote:Got this stuff the other day
not bad for 11 quid
Where did you get it from dude ?
Posted: Wed Apr 27, 2005 10:29 pm
by Davenotouring
Simon is watching the OC.... :gay:
You can get it from here..
http://www.speeding.co.uk/acatalog/Meguiars_.html
I've had good service from them before when ordering products. Careful you don't end up ordering the whole shop, which is all too easy.
I bought some Gold Class Shampoo recently which is pretty good and foamy :gay: :lol:
Posted: Wed Apr 27, 2005 10:44 pm
by E30Mark
I got mine from Halfrauds...
Posted: Wed Apr 27, 2005 10:46 pm
by Davenotouring
E30Mark wrote:I got mine from Halfrauds...
That could be easier :wink:
Posted: Thu Apr 28, 2005 10:36 am
by Splondike
Cheers guys - I may get the zaino clay bar as I presume that does pretty much the same thing, and I need to order some other zaino bits and bobs anyway...
Posted: Thu Apr 28, 2005 10:56 am
by Lowm3
Has any one tried the blue coral polish? the old range not the new products, its great!! leaves a very watery finish, makes the paintwork look wet, very shiney, ill pop some pics up of the results when i find them :D
Posted: Thu Apr 28, 2005 11:57 am
by Ceej
I used the clay bar on my car a couple of weeks ago and it worked a treat. Only problem being my car gets filthy within a couple of days :?
Ceej
Posted: Thu Apr 28, 2005 12:28 pm
by Lowm3
Here's a couple of pics ofmeguairs quick clay followed by blue corals old range put to use last week, its rained again since :(
:roll:
Posted: Thu Apr 28, 2005 12:57 pm
by Jhonno
Lowm3 wrote:Here's a couple of pics ofmeguairs quick clay followed by blue corals old range put to use last week, its rained again since :(
:roll:
mmmm shiiiney :cool:
Posted: Thu Apr 28, 2005 7:08 pm
by Simon13
yes i did forget to take some pic's how silly :oops:
Posted: Thu Apr 28, 2005 7:11 pm
by e30bemer
that stuff is the dogs danglies!!
I have got most of the meguiars range! (perk of working in a motor factors) and i use the nxt car wash, then the clay, and polish using the nxt tech wax! and she comes up a treat!
then finish off with the fancy bits like trim using nxt trim detailer!
RE:Meguairs
Posted: Thu Apr 28, 2005 7:46 pm
by Pal318is
Was always a little dubious about using the clay, but this confirms it, i'm getting some tomorrow :thumb:
Pal
Posted: Thu Apr 28, 2005 8:10 pm
by Chaos
davetouring wrote:Careful you don't end up ordering the whole shop, which is all too easy.
your not wrong there m8
Posted: Thu Apr 28, 2005 9:33 pm
by c76jon
just make sure you do a panel at atime keeping the panel well lubed
and turn your clay as you see it build up with shat
Posted: Thu Apr 28, 2005 11:20 pm
by Simon13
is there anyway of cleaning the "shat" off the clay afterwards?!
Posted: Thu Apr 28, 2005 11:28 pm
by billgatese30
i don't think so si, you jsut keep playing with the lump of clay, as you would plasticine or blutak, untill there isn't a clean face/side left to , at this point you throw it away and use another bar.
hth
Posted: Thu Apr 28, 2005 11:35 pm
by Simon13
my bar got a bit mangled in it's first use! opps
Posted: Thu Apr 28, 2005 11:37 pm
by billgatese30
good, when it gets a bit dirt on it, knead it like a ball of dough in your hands till you get another clean bit to use on the car, its when there is no clean bits left when you keep on kneading it that you throw it away and replace it.
Posted: Fri Apr 29, 2005 12:30 am
by cuk325
is this major ball ache to do??
i really want to get mine clean for the swansea show, got the 3 step meguires but still leaves swirl marks etc
Posted: Fri Apr 29, 2005 8:07 am
by M3RAGS
I find running the clay under hot water removes all the shit!
Posted: Fri Apr 29, 2005 1:50 pm
by Lowm3
Yeh run the clay under water, will get the crap off it.
Also before using it, heat the clay on a radiator or something, makes it softer, and easier to use on curved areas, so you don't miss any little bits :cool:
Posted: Fri Apr 29, 2005 9:22 pm
by Jem325i
Brought Roy some of this for Xmas and he reckons it's give him quicker 0-60 time and a higher top speed because it makes the car so smooth it cuts through the wind. :woohoo: Excellant product 10 out of 10.
