painting and sealing the underside
Posted: Mon Jul 23, 2007 8:25 pm
by staffy
i took the bumpers off to get painted and have now decided to get stuck into the underside cleaning and painting everything. what i need to know is can u do the floor and arches etc with hammerite or is it a waste of time should i just waxoil it instead ?
Re: painting and sealing the underside
Posted: Mon Jul 23, 2007 8:30 pm
by oguz327
I would at least use Waxoil although ive heard and read that Dinitrol (think thats what its called) is better but more expensive.
I think the Dinitrol stuff is self repairing if it gets chipped too.
Ill be doing this job myself before the winter months.
Posted: Mon Jul 23, 2007 8:38 pm
by oguz327
Posted: Mon Jul 23, 2007 9:01 pm
by staffy
you would just use waxoil then? and paint the other suspension parts etc i really want to go to town and have everything clean as. waxoil is a messy buisness and i will be doing it from my back so want it easy as well
Posted: Mon Jul 23, 2007 9:23 pm
by oguz327
I am no expert on these things but id certainly use waxoil or similar on the archs and floor, i am dreading the job myself but i think long term its the best way to prevent rust but i could be wrong.
Anyone else had experience treating these area's?
Posted: Mon Jul 23, 2007 9:28 pm
by Nelly
I used car body under seal by Hammerite with extra Waxoyl added - from Halfords £10.00
Posted: Mon Jul 23, 2007 9:53 pm
by staffy
that sounds like a plan thanks nelly.
oguz wats your 2.7 like in the wet ? mine is a bit of a handfull fun as f@~k though i notice lots of cars being compared to the gug and i had bought it before i was on here knowing nothing about it and yours seems to be similar so thought id ask
Posted: Mon Jul 23, 2007 9:54 pm
by 320Touring
Nelly wrote:I used car body under seal by Hammerite with extra Waxoyl added - from Halfords £10.00
Cheat!
I've done 2 coats of hammerite and will apply waxoyl seperately
its a CVNT of a job thought!
Posted: Tue Jul 24, 2007 12:02 am
by oguz327
staffy wrote:that sounds like a plan thanks nelly.
Its not too bad in the wet, the power and torque kick in more up top as it was built with track use in mind. unless i am caining it its not too bad but still have to be carefull.
I never went out in your car but from what ive heard you have more low down grunt.
Good to hear the GUGs still going strong
Posted: Tue Jul 24, 2007 7:57 pm
by staffy
oh yes the gug is still going strong! under construction till next summer prob as im going to clean up and replace whatever needs done as funds allow so she will be back better than ever
Posted: Tue Jul 24, 2007 8:14 pm
by Speedtouch
Just don't do what some stupid Yanks did (bury a brand new car in a concrete time capsule and dig it up 50 years later!)
http://www.buriedcar.com/tulsarama.asp
Posted: Tue Jul 24, 2007 8:22 pm
by staffy
no way man i have been in hospital so cant drive for a couple of months and i have a company car so now was a good time to get at it.
Posted: Wed Jul 25, 2007 6:50 pm
by jibowski
that waxoyl balck underseal stuff is top notch, and i use the clear inside the doors and use an aerosol can with straw to get into all the little holes, (i likes litte holes!)arf arf
Posted: Wed Jul 25, 2007 8:14 pm
by kevin316i
I bought some 3M body schutz, which is supposed to remain flexible. Plan to do the arches first and then touch any areas underside then rather than coating the whole lot.
My experience with Waxoyl was a pretty poor one. I bought the tin and applicator gun, warmed the waxoyl in hot water but as soon as it came out the gun is congealed straight away and the only thing that got covered was my f**king overalls! Bought aerosol cavity wax afterwards (tereson by Henkel) which is very handy for inside sills etc, but very thin.
