rear view mirrors
Posted: Sun Jul 22, 2007 12:52 pm
by ChrisBarns
Are convertible rear view mirrors the same as all the others?
ta
Posted: Sun Jul 22, 2007 12:56 pm
by Simon
Short answer, no!
Re:
Posted: Sun Jul 22, 2007 1:00 pm
by B7
The saloon mirror fixes into the roof above the screen. The convert mirror has a twist fixxing to the glass via a triangular spring clip.
However, it lists the convert mirror as also fitting the e39 and 46............which means an auto dipper from a 39 would fit :D
Part 51161932854 (INTERIOR REAR-VIEW MIRROR) was found on the following vehicles:
E30: Details on E30
E30 318i CONVERTIBLE, Euro
E30 320i CONVERTIBLE, Euro
E30 325i CONVERTIBLE, Euro
E30 M3 CONVERTIBLE, Euro
E39: Details on E39
E39 520d TOURING, Euro
E39 520d SEDAN, Euro
E39 520i TOURING, Euro
E39 520i SEDAN, Euro
E39 523i TOURING, Euro
E39 523i SEDAN, Euro
E39 525d TOURING, Euro
E39 525d SEDAN, Euro
E39 525i TOURING, Euro
E39 525i SEDAN, Euro
E39 525td SEDAN, Euro
E39 525tds TOURING, Euro
E39 525tds SEDAN, Euro
E39 528i SEDAN, Euro
E39 528i TOURING, Euro
E39 530d TOURING, Euro
E39 530d SEDAN, Euro
E39 530i SEDAN, Euro
E39 530i TOURING, Euro
E46: Details on E46
E46 316i SEDAN, Euro
E46 316i TOURING, Euro
E46 316i 1.6 SEDAN, Euro
E46 316i 1.9 SEDAN, Euro
E46 318d SEDAN, Euro
E46 318d TOURING, Euro
E46 318i SEDAN, Euro
E46 318i TOURING, Euro
E46 320d SEDAN, Euro
E46 320d TOURING, Euro
E46 320i SEDAN, Euro
E46 320i TOURING, Euro
E46 323i SEDAN, Euro
E46 325i SEDAN, Euro
E46 325i TOURING, Euro
E46 325xi TOURING, Euro
E46 325xi SEDAN, Euro
E46 328i TOURING, Euro
E46 328i SEDAN, Euro
E46 330d TOURING, Euro
E46 330d SEDAN, Euro
E46 330i TOURING, Euro
E46 330i SEDAN, Euro
E46 330xd TOURING, Euro
E46 330xd SEDAN, Euro
E46 330xi TOURING, Euro
E46 330xi SEDAN, Euro
Z1: Details on Z1
Z1 Z1 ROADSTER, Euro
Z3: Details on Z3
Z3 Z3 1.8 ROADSTER, Euro
Z3 Z3 1.9 ROADSTER, Euro
Z3 Z3 2.0 ROADSTER, Euro
Z3 Z3 2.2i ROADSTER, Euro
Z3 Z3 2.8 ROADSTER, Euro
Z3 Z3 2.8 COUPE, Euro
Z3 Z3 3.0i ROADSTER, Euro
Z3 Z3 3.0i COUPE, Euro
The one I'm looking for is a genuine convertible Sport mirror with the reading lights!!!!!
Re:
Posted: Sun Jul 22, 2007 1:05 pm
by ChrisBarns
mine's just got the circle where it must have stuck on. I need to get this off first (white spirit?) then stick a whole assembly back on. BTW how do auto dipping mirrors work?
Posted: Sun Jul 22, 2007 1:07 pm
by ChrisBarns
ps - thanks for rapid and detailed response!
Re:
Posted: Sun Jul 22, 2007 1:17 pm
by gazza
i have heard about the e39 auto dipping mirror and people who have been ripped of on ebay over them as the mirror has a seperate control unit and it will not work without it im not 100% but i dont think the control box can be removed as its part of the dash electrics. ....when removed from a e39 they are useless but in ebay tradition they forget to tell you this
if you fit it to a convertible it will need to be wired so you will need to run wires up your screen where they can be seen
the e30 sport mirror can be made to fit a cab see the following link
http://www.cardomain.com/ride/339610/2
Re:
Posted: Sun Jul 22, 2007 1:25 pm
by gazza
by the way chrisbarns is that circle in metal on your windscreen if it is, thats all you need to fit the mirror if its a glue mark then the metal disc is still available from the dealer part number 51 31 8 145 530 costs about £4
Re:
Posted: Sun Jul 22, 2007 1:32 pm
by ChrisBarns
car isn't with me at the moment - will check when i get it back tommorow. From memory I had thought its a rubbery glue circle but I didn't investigate it closely.
Re:
Posted: Sun Jul 22, 2007 1:36 pm
by gazza
if its just glue it will clean off but you will need the metal disc to fix the mirror use a good blade in a scraper and some thinners just be carefull not to scratch the glass .....my local rac windscreens did mine for free
Re:
Posted: Mon Jul 23, 2007 11:34 am
by ChrisBarns
edit - was replying to different post. Don't know how to remove...
Posted: Mon Jul 23, 2007 9:14 pm
by Simon
The delete button!
Re:
Posted: Mon Jul 23, 2007 9:56 pm
by Demlotcrew
B7 wrote:The one I'm looking for is a genuine convertible Sport mirror with the reading lights!!!!!
Good luck BMW never did one for the E30 cab
Re:
Posted: Mon Jul 23, 2007 10:12 pm
by B7
What a con!!! You pay all that dough and they stick a standard mirror in them. I just took it for granted that being a sport it would have had a sport type mirror. Learn something every day.
Cheers. I'm now off to convert one.
Re:
Posted: Mon Jul 23, 2007 10:15 pm
by Simon
Is that a definite?
ETK shows them as available for a 325i?
Re:
Posted: Mon Jul 23, 2007 10:17 pm
by B7
What for a cab? Chuck us the link. Cheers
Re:
Posted: Mon Jul 23, 2007 10:18 pm
by ZedOne
B7 wrote:Part 51161932854 (INTERIOR REAR-VIEW MIRROR) was found on the following vehicles:
So that means the auto-dip mirror I have sat in a box can be fitted to my Zed?? winkeye winkeye
(not that I ever get to drive it much in the dark.... :( )
Re:
Posted: Mon Jul 23, 2007 10:21 pm
by B7
I'm sure there was an article on the e36 copue fsite where russ fitted an auto dipping mirror to is non auto dipping e36. And I don't recall him having any box of tricks to wire in either.
I'll go check.
Re:
Posted: Mon Jul 23, 2007 10:27 pm
by B7
http://www.e36coupe.com/
On there under the techical section. Interesting though that he used an e36 mirror (not listed above as being compatible) yet the fixing on his screen looks identical.
Re:
Posted: Mon Jul 23, 2007 10:45 pm
by ZedOne
B7 wrote:Interesting though that he used an e36 mirror (not listed above as being compatible) yet the fixing on his screen looks identical.
Just checked the part number from the E36 mirror/screen fixing (51 31 8 145 530) and it is the same as for the E30 cab, Z1 and all the others (and more) you listed above.
This means the auto dip mirror I have WILL fit the Zed, you CAN get one for your cab and make it different to having a set of map lights winkeye
Happy days...... :D :D
P.S. Thanks for the link to the mirror fitting guide.... :wink:
Re:
Posted: Mon Jul 23, 2007 11:19 pm
by Danhbmw
I can't be bothered to read the guide so it will probably say in there, but there is NO box of tricks, the circuit board is in the mirror housing and the mirror can be darkened by just using a PP3 battery!!
Basically all you need to get one running properly in an e30 is:
1, an ignition live (not permanent or your battery will be drained!)
2, an earth
3, a reverse signal (not sure if its +ve or -ve on E46) - this makes it go clear so you can see out of it when reversing!!
:thumb:
Re:
Posted: Tue Jul 24, 2007 6:49 am
by B7
Ah but which one will i go for????? Tempted but the auto dip but still love the map lights. Decisons decisions.
Re:
Posted: Fri Aug 03, 2007 6:42 pm
by B7
Went for the map lights and it's in and working on my convertible. Peice of p*** as well. Had to change the arm that fixes to the screen from my old mirror to the map light mirror. The only difference is that on the sport the wires run through the mounting arm. I've had to run a descreet back wire into the header rail trim but it looks fine.
Well chuffed.
I'd like to sort the wire out so it's a bit neater but I'm thinking on that one.
