Wet boot!
Posted: Tue May 01, 2007 11:11 pm
by bigjohn55
why have i got a lot oe condensation in my boot.this afternoon i mopped out some water out of the sparewheel compartment and wiped dry all the wetness from the inside of the bootlid and dried out the foam behind the toolkit :cry: .is there anyway to prevent it from doing it again . :? :?
Re: Wet boot!
Posted: Wed May 02, 2007 7:31 am
by smithy318i
there are a few common problems for water in the boot.
1st. (and most common and simple to fix) check the light cluster seals and tighten the nuts if needed.
2nd. the rear sunroof drains are not located properly in the stale air vents (or are blocked).
3rd. leaking bootlid seal
4th. holes in the bottom of the car.
Re: Wet boot!
Posted: Wed May 02, 2007 7:40 am
by Chris-W
Also failure of the foam gaskets on the spigots behind the 'Hoffmeister Kink' trim on the c pillars.
Re: Wet boot!
Posted: Wed May 02, 2007 8:37 am
by bigjohn55
Thanks CHRIS-W & SMITHY318i, will investigate!!!!!! :D :D :D :D
