18 inch wheels
Posted: Mon Mar 19, 2007 9:31 pm
by Mark325i
Hi lads, new to this site, i was told this is the best place for some help. im looking for a set of 18s for my sport but im finding it very hard to find 4x100s that have a dtm style or bbs style? i was told bbs dont do anything in 18s so just wondering do anyone no if rial or some other make do anything???
thanks for any help
Re: 18 inch wheels
Posted: Tue Mar 20, 2007 8:57 am
by Rosc0PColtrane
Trawling the internet is your best bet mate. There are a couple of cars on here with 18's, but most people prefer 15's or 16's, so may not have an answer. Try the syling/ICE section, you may have some more luck there.
There are a handful on here into big tuning and styling, you just need to find them!!
Good luck and welcome!
What car do you have?
Put up pics of it!
Re: 18 inch wheels
Posted: Tue Mar 20, 2007 12:12 pm
by motorsport
18" x 8J BK Alpina Replicas fitted with 4x100 pcd, absolutely no rubbing issues and a very smooth ride.
Using standard mtech suspension.
Try this BK racing link, they do a 299 model alike BBS/DTM
I've seen these in silver on a silver E30 on this site, they looked superb
http://www.bkracing.co.uk/aspbite/alloy ... l.asp?ID=1
Andy
Re: 18 inch wheels
Posted: Tue Mar 20, 2007 8:20 pm
by Mark325i
ya thanks for the help lads, its a 1990 325i sport, didnt get the chance to take pics yet but will post when i do, i have 17` alpina reps but im trying to go for a diffrent look.
Re: 18 inch wheels
Posted: Tue Mar 20, 2007 8:26 pm
by fowler
stay with 17's fella tops the rolling radius is all wrong and will only give you problems in the long run
just try find some wheels you like thaat are a bit different. you can use ford/ vw rims 4x100 but just check the wheel offset
Re: 18 inch wheels
Posted: Tue Mar 20, 2007 8:39 pm
by Rosc0PColtrane
go for 18's if you want. There's a chap on here called Henry with an M3 on 18's. The touring cars ran 18's too!!!!
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 8:51 am
by motorsport
Rolling radius can be kept the same if you fit the appropriate tyre.
Cheers,
Andy
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 8:54 am
by E30Mark
blatantarrogance wrote:go for 18's if you want. There's a chap on here called Henry with an M3 on 18's. The touring cars ran 18's too!!!!
but all in 5 stud!!
original post wanted 4 x 100's
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 9:42 am
by Rosc0PColtrane
Illustrating wheel size... What effect does a different stud pattern have?
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 9:48 am
by Ziggy
fowler wrote:you can use ford/ vw rims 4x100 but just check the wheel offset
Most fords are 4x108 mate... sure you knew that, but just didn't want him running off & buying ford wheels then blaming you!
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 9:51 am
by Ziggy
blatantarrogance wrote:Illustrating wheel size... What effect does a different stud pattern have?
Cos the whole point of the thread's that he's struggling to find the wheels...
Thankfully he's already decided to get them, rather than letting everyone talk him out of what he wants
Has anyone looked into spacer/5-stud converter jobbies recently? Would be a whole lot easier to find wheels in 5x120 or whatever...
Re: 18 inch wheels
by E30Mark
Mainly the wheel won't fit!
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 10:26 am
by Rosc0PColtrane
hahaha I wasn't implying they would, availability aside, I wondered if there was any benefit to having 5 studs!
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 11:01 am
by munky30
25% more strength holding the wheel on than a 4 stud?
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 11:37 am
by aceraf
motorsport wrote:18" x 8J BK Alpina Replicas fitted with 4x100 pcd, absolutely no rubbing issues and a very smooth ride.
Andy
slightly off the point, but what profile tyres are you running?
Also, how much is your car dropped?
I wana drop my car 60mm all round...you reckon there's any chance of no rubbing without having to roll/cut the arches?
Re: 18 inch wheels
Posted: Wed Mar 21, 2007 11:49 am
by motorsport
Off topic but happy to give any advice.
215/35/18 tyres
Standard mtech springs and shocks, however using coupe rear springs as they are a little softer than convertible/tourer variants and therefore give a slight drop. I had to consider hard top weight too as this drops the profile also.
Absolutely no rubbing issues at all Tested at all speeds/with passengers/full steering lock etc. No arch modes neither.
Regards,
Andy
