LSD
Posted: Sun Dec 17, 2006 10:27 pm
by nolc
Can you tell if an LSD is fitted without taking it out and looking ?Local lad scrapping a 6 cylinder 2.0 reckons it has one fitted.
Re: LSD
Posted: Sun Dec 17, 2006 10:29 pm
by mwarrior
spinning the back wheel when its jacked up is the best sighn if the other wheel spins in the opposite direction then you have lsd..........i thing someone may need to back me up on this one
Re: LSD
Posted: Sun Dec 17, 2006 10:30 pm
by Theo
Yup - easiest way is to jack the car up on the diff so both rear wheels are of the ground (remember to chock the front wheels) Have the car out of gear with the handbrake off, spin one of the rear wheels, of the other one spins in the same direction - it is an LSD!
Re: LSD
Posted: Sun Dec 17, 2006 10:31 pm
by nolc
Im thinking same as you,just better to ask
Re: LSD
Posted: Sun Dec 17, 2006 10:55 pm
by Steve-E30
mwarrior wrote:spinning the back wheel when its jacked up is the best sighn if the other wheel spins in the opposite direction then you have lsd
Both wheels should spin the same way with a Lsd :wink:
Re: LSD
Posted: Sun Dec 17, 2006 11:01 pm
by Richy325iTouring
mwarrior wrote:spinning the back wheel when its jacked up is the best sighn if the other wheel spins in the opposite direction then you have lsd..........i thing someone may need to back me up on this one
same direction
Re: LSD
Posted: Sun Dec 17, 2006 11:03 pm
by Theo
When I posted the 'yup' was in response to the initial post, not the advice from the first chap!
Re: LSD
Posted: Mon Dec 18, 2006 5:28 pm
by nolc
Thanks for that :thumb:
Re: LSD
Posted: Thu Dec 21, 2006 10:58 am
by DJ_B4L
so if they spin in the same direction this its a LSD?
or if they spin different ways then its a LSD
which one?
Re: LSD
Posted: Thu Dec 21, 2006 11:02 am
by Speedtouch
Same direction = LSD
Opposite direction = Open
Re: LSD
Posted: Thu Dec 21, 2006 1:05 pm
by DJ_B4L
thanks for that
Re: LSD
Posted: Thu Dec 21, 2006 1:14 pm
by cliffybabe
2 thick black lines lef ton the road behind u is the easy way to find out winkeye
Re: LSD
Posted: Thu Dec 21, 2006 1:25 pm
by Douzeper
Would jacking one side up and trying to spin the wheel by hand not give you the same conclusion?
Doesnt spin by hand - LSD
Does spin - open
Re: LSD
Posted: Thu Dec 21, 2006 1:26 pm
by cliffybabe
no cos u cant see if both wheels spin the same way
Re: LSD
Posted: Thu Dec 21, 2006 1:31 pm
by Douzeper
Yer probably right but..... if it was LSD it wouldnt spin? if it was open it would?
No?
Re: LSD
Posted: Thu Dec 21, 2006 2:08 pm
by jpboost
Douzeper's right,
If the car's got a slipper, and you only jack one wheel, then it's difficult to turn. as it's pretty much linked to the other wheel that's not moving. Not impossible to turn though, I can turn mine (just) by hand. I think they can get easier to turn as the diff wears. Mine's rebuilt less than 5k ago FWIW.
Re: LSD
Posted: Thu Dec 21, 2006 5:26 pm
by Speedtouch
Can't you just fill an open diff with thick grease to get the LSD effect? :wink:
Re: LSD
Posted: Thu Dec 21, 2006 6:35 pm
by H35-IAN
hehehee just put it on full lock and drop it at about 4k rpm lol if u can do rings u got a slipper if u start spinning just a wheel its a homo diff!!
so be carefull in this weather either can be good fun tbh but lsd pisses on homo open diffs! :cool:
Re: LSD
Posted: Fri Dec 22, 2006 12:09 am
by billgatese30
H35-IAN wrote:hehehee just put it on full lock and drop it at about 4k rpm lol if u can do rings u got a slipper if u start spinning just a wheel its a homo diff!!
homo diff Image
Re: LSD
Posted: Fri Dec 22, 2006 12:25 am
by Richy325iTouring
cliffybabe wrote:2 thick black lines lef ton the road behind u is the easy way to find out winkeye
not a def there either
ive left 2 lines with an open diff
quite a few at lakeside can confirm that
think booty blaimed some chavs in a nova after me and karan pratting about
Re: LSD
Posted: Fri Dec 22, 2006 3:33 pm
by Globulator
'ss easy. An LSD links the two wheels together.
Stick car in neutral
Disengage handbrake
Retrieve car
Chock front wheels
Disengage handbrake, check for neuttral.
Jack up ONE read wheel.
If it is very difficult to turn you've got an LSD - as it's trying to turn the other wheel
If it moves pretty easily you haven't, as propshaft just spins.
Re: LSD
Posted: Mon Jan 29, 2007 3:30 pm
by clubfx2
Nice response cliffy, that's how i'd check it tooo....
Re: LSD
Posted: Mon Jan 29, 2007 7:25 pm
by ash-e30
yes sounds right or u could just toe and heel it n find out if both wheels light up or spin her round see if it goes round easy enough as u can normaly tell if u try and donut as it will push on or you can hear 1 wheel spin :D
Re: LSD
Posted: Tue Jan 30, 2007 5:41 am
by yz_250
Normaly only the 325is,M3 and the 333i got lsd and 318is was optinal lsd but other then that the other e30 was open saw it when i did some resurch on lsd a wail back !
