South African e30's differences to UK models?
Posted: Mon Nov 06, 2006 3:07 pm
by dobbie82
I have seen a few south african imports for sale, though 2 of them had chrome arches and i wouldnt touch chrome arches with a barge pole!
Were they made in South Africa then?
Its the aircon that temps me most winkeye But were the bodies galvanised or do they rust just as much as the UK models?
Re: South African e30's differences to UK models?
Posted: Mon Nov 06, 2006 3:19 pm
by Conan
I think there was a 333i or somthing built over there. Wouldnt mind one of them!
Posted: Mon Nov 06, 2006 4:01 pm
by eamo
dobbie82 wrote:I have seen a few south african imports for sale, though 2 of them had chrome arches and i wouldnt touch with a barge pole!
i would be the opposite - if you can find one grab it - no rust issues due to the climate!!
Posted: Mon Nov 06, 2006 4:03 pm
by dobbie82
Sorry post edited now, i meant i wouldnt touch one with chrome arches as you dont know whats underneath.
DOes anyone know where they were built then and why they are better than the UK ones?
Posted: Mon Nov 06, 2006 4:13 pm
by f13ldy
From my knowledge of E36s.
The M3 had slightly different pistons and compression ration which made marginally less power. To cope with the lower grade of fuels...
Some cars had the cooling system upgraded and the extra rust proofing because of the corrosive coastal areas.
As I say tho this related specifically to E36s so possible similar to the E30s.
Also they normally have oodles of options and are cheaper than UK cars.
Posted: Mon Nov 06, 2006 4:22 pm
by boomer
They're not better than the UK ones - just specced up differently I think.
Rust is rust - On my 320 (built '89, imported '91) all 4 doors have rusts, sills & F/R arches are showing spotting and the sunroof panel has a spot.
Mine has beefed up suspension - a curious combination of mtech arbs, very stiff springing and 45mm front struts. And it had a sumpguard fitted.
The radiatior is bigger than UK spec as well and the air filter box takes an M3 sized filter panel (the filter box has a rubber valve on the bottom of it for letting out sand and dust).
They may have aircon fitted which is good....if it works, and a pain in the ass if it doesn't work (the old lady who sold me mine said she'd never had the aircon on since importing it - didn't need it in this country 8O )
Mine also has cruise control fitted which is a very good thing if you do mucho miles on M-ways
Other than that the interior may be different - mine has comfort learther seats with vinyl door cards
And the speedo will read in kmh rather than mph
And it have a check computer that has a seatbelt warning sign :D
I know they were built in SA but I don't know where.
HTH
Posted: Mon Nov 06, 2006 6:33 pm
by ian325is
The E30's were all built at a plant near Pretoria. Local content rules require something like 50% by value to be locally produced so these are much more than CKD's like alot of other plants around the world. Most of the models are identical to the UK cars but are usually highly specced. We don't have salt on our roads but rust is an issue for cars sourced from the coast. The bodies were not galvanised and rust proofing was probably on a par with UK versions. Inland though, you can even find Alfasuds without rust!
We also had some fantastic limited production runs of some very special cars, usually homologation specials produced with standard production racing in mind. Our 745i's were equiped with the 24 valve 3.5 straight out of the M1 and we also had the 333i with a 3.3 litre from the 733. Probably the most succesful was our 2.7 325is. They started off with all the Alpina goodies and developed it from there. Special Alpina cams, pistons and heads, 324td crank, six branch exhaust and wide diameter free flow silencers, K&N panel filter in a modified airbox, 535 air flow meter, aluminium panels and full M3 suspension! Straight from the factory!
Hope this helps
Ian
Re:
Posted: Tue Nov 07, 2006 7:26 am
by mrLEE30
if you want a highly specced car then go for the Aussie imports.. they were made in Japan and are almost all full spec - ac, leccy bits, sport seats, etc etc and most are very low milage due to jap MOT system, vely strickt! and i have yet to see one over here with almost any real rust, except the shitters that have been bashed about and crashed.
my 325 sport bought with 86,000km (1987 model) and my cab bought with 80,000 1992 model but mine were LHD, the aussies got the RHD versions! both had no rust, even my diff was not rusty!!!
mrlee
Re:
Posted: Tue Nov 07, 2006 7:43 am
by drifty325i
You think the Ausy ones are good you should see the Kiwi ones :cool:
Posted: Tue Nov 07, 2006 8:38 am
by jon_pure_british
boomer wrote:They're not better than the UK ones - just specced up differently I think.
HTH
slightly offtopic
where can i get a sump guard from? im assuming that it came fromthe higher spec models?
Posted: Tue Nov 07, 2006 8:40 am
by mrLEE30
i had noticed your in the past !!! but think you need to close your bonnet fully :eek: or adjust the catch!!!
Posted: Tue Nov 07, 2006 8:44 am
by mrLEE30
jon... part no. 51 71 1 971 001 - front aggregate protective plate... but note they are different for pre and post face lift around 150notes IIRC
mrlee
Posted: Tue Nov 07, 2006 8:49 am
by drifty325i
My turbo is sooooo massive it wont close lol, na we just had the bonnet off
getting ready for paint winkeye
Posted: Tue Nov 07, 2006 9:08 am
by mark_i
Fascinating thread this one as I lived in SA from 84 to 92. Before I got married, 5 of us shared a house in Pretoria and two of the guys actually worked at the BMW plant
www.bmwplant.co.za/
Every six months they would get a new car as part of the deal and was fascinating to see the evolution of the e30.
One of the dudes was a buyer for the BMW accesories and he got me a brilliant briefcase made from the same quality leather as the upholstery. The other guy sourced BMW parts that were made locally such as alloy wheels and exhausts.
The engines and body panels were imported and the build quality was excellent. Can't recall the VIN for an SA built version. strangely the post 88 facelift never received the smiley headlamps.
Chrome wheel arches were not standard
My first e30 was a 320i, i've still got the receipt and paid R50000 in 1989 from Auto Bavaria in Rosebank, Johannesburg. Also got the SA 3-series brochure from 1989.
Posted: Tue Nov 07, 2006 11:42 am
by CiLK_WuRM
My SA spec car came with M3 suspension and brakes, a 2.7 and some nice aluminium alloy panels. Result :D
Posted: Tue Nov 07, 2006 7:11 pm
by jmc330i
CiLK_WuRM wrote:My SA spec car came with M3 suspension and brakes, a 2.7 and some nice aluminium alloy panels. Result :D
Thats the SA 325iS - its what the UK 325i Sport should of been :x
Posted: Tue Nov 07, 2006 8:33 pm
by koos
I think they were built in Roslyn. 325iS was a machine, never seen a 333i. 325iS had the option of Air-con or P/S, not both. Sump guards were really strong for what they were, 4mm steel I think!!!
Posted: Wed Nov 08, 2006 5:18 am
by mrLEE30
333i was not really that quick to my understanding, a good 2.7 would be faster, i think the numbers sound good but an old 7 series engine in there produced short of 200hp and 250ish Nm (IIRC). It was however treated to Alpina goodies such as interior, rims, suspension and a tech 1 kit and was designed by a young Bernd Pischetsrieder (say that name when youve had a skin full :eek: )
mrlee
Posted: Wed Nov 08, 2006 5:18 pm
by Andyboy
Aussie cars would have been German built - although E36's were built in Malaysia. All SA E30's including the 316 had the big 325i type diff. As a rule the rustproofing wasn't very good. Pacerpete and I went to see a 24v 745i that was absolutely rusted out and needed a reshell which for a 1986 E23 was pretty exceptional. SA cars don't have the black plastic panel between the rear lights either.
Posted: Wed Nov 08, 2006 5:25 pm
by e21Jason
Hi
Any good leads for sourceing an SA 325IS, web sites ets in SA.
Jason
Posted: Wed Nov 08, 2006 5:30 pm
by ian325is
Just a quick correction. It was the 333i that was available with either power steering OR air con, due to space constraints. The 325iS was equiped with both. Will try and get some figures for outputs and performance. The 333i was pretty quick but also a bit of a beast. 325iS was definately the better car in terms of handling though, and quicker over a lap.
Posted: Wed Nov 08, 2006 5:35 pm
by ian325is
Good 325iS's are very hard to come by. Only a few hundred were produced and they are highly sought after. Unfortunately, a lot of them have also been used and abused. There is currently one for sale near me which I am considering. Price is around 5500 pounds though. How much would shipping to the UK and duties etc cost?
Re:
Posted: Wed Nov 08, 2006 7:29 pm
by Gwynleym10
Seat belts are different , can't plug a SA belt into a German catch or visa versus.
Sump guards are loud when they hit speed bumps, and on a lowered car that is all the time!
My old SA 316 had some rust
I think all have rear ARB's (well coat hanger...)
Many have longrange fuel tanks, I used to be able to get over 400 miles to a tank! Then take 1/2hour to fill it up!
Re:
Posted: Wed Nov 08, 2006 10:09 pm
by dannosail
SA cars were well specced, I have 325i Saloon, came wit the same as Boomers but with Long Range fuel tank fitted as standard as well, on a good run I can get best part of 400miles out of it!
I'm not sure if the sound proofing is as good though, my Touring seems a lot quieter?
Re:
Posted: Thu Nov 09, 2006 7:16 am
by ravennexus
looking at this reminds me to get the AC in my 87 325i recharged for next summer.
Re:
Posted: Thu Nov 09, 2006 9:37 am
by mark_i
you can probably credit that one on a Mr Foster, buyer at the Rosslyn plant in the late eighties... you should have seen some of the gear he got given as "thanks for the business Foz"
Re:
Posted: Tue Nov 21, 2006 1:51 am
by CiLK_WuRM
My 325iS has both P/S and A/C.
Its got the rear plate filler too.
Re:
Posted: Wed Nov 22, 2006 5:34 pm
by RPower
CiLK_WuRM wrote:My 325iS has both P/S and A/C.
Interesting... :D
Do you have more info about 325is SA Spec? (Max Power,Torque,drivetrain,wheels,brakes,0-62,max speed,etc)
I´ve read that there were EVO versions for the 325is SA Spec. A EVO I with around 195hp and a EVO II with 210hp...
Is that true? :roll:
EDIT: Can anyone help?
Posted: Sat Nov 25, 2006 4:48 pm
by ian325is
That sounds about right. I.ve got the specs and road tests somewhere. Will have a look and see what I can find.
Posted: Mon Nov 27, 2006 5:09 pm
by RPower
ian325is wrote:That sounds about right. I.ve got the specs and road tests somewhere. Will have a look and see what I can find.
Thanks a lot :wink: :D
