Do the wheels off a new BMW Mini fit an E30 3 series????
Posted: Wed Aug 02, 2006 5:44 pm
by scarlaton
I need new wheels and have a good offer on some BMW Mini wheels.
I know both cars a 4 stud.
Anyone help please??
James
Re: Do the wheels off a new BMW Mini fit an E30 3 series????
Posted: Wed Aug 02, 2006 5:48 pm
by Falkster
The PCD is the same, as is the centre bore but you will probably need some spacers as the Mini wheels run 35mm offset
Posted: Wed Aug 02, 2006 5:49 pm
by dazleeds
i think the studs match
but the offset is a fair bit different i think
so you would need spacers to fit them
but i could be wrong?
Posted: Wed Aug 02, 2006 5:50 pm
by tregzybmw
The bolt pattern is 4x100mm.
The centerbore is 56.1mm.
The offset (ET) can range from 35mm to 52mm depending on the wheel size.
this means that, as far as i know, everything is ok, but the offset is too high. you will need pro-spacers, of around 30mm...this isnt the best thing to do, i would say 10-20mm spacers at most really
Re:
Posted: Wed Aug 02, 2006 5:51 pm
by tregzybmw
before you ask, they sell them on this site:
click me!!
