Who can identify these bits?
Posted: Sun Jun 18, 2006 5:24 pm
by Jay07
Hey people!
I was going thru my tool box and i found a few bits that must have come with the beemer. Two are obviously relays - the yellow has 601.576 on it and the white has a circuit diagram on one side. They might be spares but i was wondering if they should be somewhere!
Not sure about the rest...Any1 shed some light?
Posted: Sun Jun 18, 2006 5:28 pm
by stuartgallafant
B is a locking wheel nut cap
C is likely to be the fuel pump, or even the ABS relay
and D is likely to be the DME relay
not quite sure what A are from
hope this helps. correct me if im wrong anyone
Posted: Sun Jun 18, 2006 5:30 pm
by jmc330i
'A' looks like the plastic clips that hold the carpet down in the footwells.
Posted: Sun Jun 18, 2006 5:34 pm
by fuzzy
id agree with A being the clips that hold down the mats in the footwells.
by dobbie82
yep jmc is right, they are just the things that hold the mats down.
Posted: Sun Jun 18, 2006 6:04 pm
by keith52
a, i think you'll find are the clips which hold the covers which sit behind the h/lamps in the engine bay
Posted: Sun Jun 18, 2006 6:06 pm
by ian332isport
keith52 wrote:a, i think you'll find are the clips which hold the covers which sit behind the h/lamps in the engine bay
Nope, deffo for the mats
Posted: Mon Jun 19, 2006 9:06 am
by dobbie82
A deffor for the mats cos I found one in the touring and it matched the other 3 holding the mat down
Posted: Mon Jun 19, 2006 9:24 am
by Jay07
Cheers ladz!
The verdict for;
(A) is def for holding the mats down!
(B) as above is a cap for the locking wheel nut - never noticed them on the other wheels before!!
This is the only info ive had on the relays, cheers stuart. I'm pretty sure i dont have ABS - What does DME stand for?
Posted: Mon Jun 19, 2006 1:45 pm
by stuartgallafant
DME - Digital Motor Electronics...
its basically the ecu/engine management system that runs your engine. when the ignition is switched on, the relay sends power to the DME to turn it on
likewise, when the ignition is switched on, the other relay sends power to the fuel pump, priming it ready for fuel delivery on engine cranking (starting)
HTH
Re: Who can identify these bits?
Posted: Mon Jun 19, 2006 2:47 pm
by danny_j
Jay07 wrote:Hey people!
I think C is the DME relay? I know its defo white
Posted: Mon Jun 19, 2006 2:48 pm
by Templ8e30
Never seen a yellow relay like D on an E30, plenty on 5 series though.
C is definately 100% your DME relay.
Cheers,
Iain T
Posted: Mon Jun 19, 2006 3:55 pm
by stuartgallafant
i knew one of them was the DME relay, i just couldnt remember which colour!!
so if white is the DME relay, then the other should be the fuel pump relay. although as Templ8 says, it looks yellow, as opposed to orange
Posted: Tue Jun 20, 2006 6:43 pm
by keith52
i stand corrected , i've actually just removed them from an SE , i thought they were build into the carpet
