noisey M42
Posted: Mon May 08, 2006 10:39 pm
by appletree
thought my 318is sounded abit noise so i went to a bmw specilist to have alook and when the bloke had a look at he said it was a little top end noisey tappety.
he said that it may just be a couple of worn out hydrolic tappets but to get the right ones he'd have to change them all. so thats £10+VAT each which is about £188 + while hes there i might as well do the cam chain/sprockets and water pump
so has anyone else done this resently how may £Â£Ã‚£Ã‚£Ã‚£ will it cost me including LABOUR??
anything else to do while am there?
Posted: Tue May 09, 2006 12:35 am
by Dan318-is
what sort of noise?
if it a ticking clean your injectors first before you think about anything else
injectors
Posted: Tue May 09, 2006 5:49 pm
by appletree
I've run sum red x through it and it made a very slight difference?
its quite loud and you can hear it over the normal engine noise at any revs especaily when you accelerate then let it coast.
Posted: Tue May 09, 2006 6:01 pm
by TheDutch
Have you checked it's not a cracked exhaust manifold? Seems to be a more common problem on these cars.
noise m42
Posted: Tue May 09, 2006 6:04 pm
by appletree
Ya the mech is a sound guy and loves his E30s
an got a very nice IS his self
, he said its not that and sounds topend to him, which is what me dad thought aswell.
Posted: Tue May 09, 2006 6:12 pm
by hammoj28
Hmm, i have a kinda ticking noise which sounds like exhaust noise on mine. Never been able to suss out where it was coming from though. Might be the manifold. How much is a new manifold and where do you get one?
Posted: Tue May 09, 2006 7:44 pm
by appletree
A super sprint stainless one
is £444 dont know about a BMW one or a GSF equivelent
Posted: Tue May 09, 2006 7:51 pm
by Bob_S
I've heard a new bmw manifold is about 400 notes
NOISY KNOCKER
Posted: Tue May 09, 2006 8:25 pm
by rc
My m42 is noisy aswell tho it's the timin chain tensioner, Heard a different m42 and its tappets usually go quiet once warmed up-
. But am no mechanic
Re: NOISY KNOCKER
Posted: Tue May 09, 2006 8:34 pm
by Dan318-is
rc wrote:My m42 is noisy aswell tho it's the timin chain tensioner, Heard a different m42 and its tappets usually go quiet once warmed up-
If it goes when warm then its likely that its the injectors. I had the exact same problem on mine, cleaned them up with carb cleaner and my tapping completely stopped, If you take time to remove the injectors youl be shocked at how dirty they are. Even if it doesnt do the job then its worthwhile doing anyway. My mates old faded Red Is had tappet issues and it made noises at all operating temperatures
if you think its the manifold can you not examin it for cracks?
Posted: Wed May 10, 2006 10:28 pm
by appletree
just got the quote from the garage
are you Sat DOWN???
£1200
For:
Cam chain and all the gear to go with it
Water pump
16 tappets
labour
or £1600
for the above and new camshafts if it needs them
What you all think???
Posted: Wed May 10, 2006 10:42 pm
by stonesie
i think he thinks you are minted
Posted: Thu May 11, 2006 12:07 am
by TheDutch
If you need someone to tell you not to bother I'll be free after 5:30...
Normally, no one ever bothers changing tappets, and no one ever needs to change cams on these engines. By all means change the water pump and chain if it's done a lot of miles.
Posted: Thu May 11, 2006 7:37 am
by E30Mark
go down to Halfords and buy a bottle of Wynn's hydraulic tappet cleaner, pour it in your oil and drive it. I had a bad tap on one of my tappets, this cured it! but then the head cracked a while later! obviously nowt to do with the additive, so i can't tell you the long term effectiveness of this treatment.
You'd be better off sourcing a 2nd hand engine, or teach yourself mechanics!
Posted: Thu May 11, 2006 8:26 am
by Dan318-is
The tappet cleaner mark mentions is an extremely thin oil and will wear your engine out at a faster rate than it wears now. It allegedly breaks down the oil and claens the tappets that way
Like i said before, clean your injectors first i would put money on these tapping!
IF you do use the tappett oil, dont rag the car while theyr in there. were talkin no higher than about 4k? once its been in there for a day or too flush it out and change the oil. A BMW mechanic told me that another method is to chuck it in neutral, jam the accelerator on so that the engine is running at about 3000rpm, and leave it for an hour?
Before you go doing any of this though i would clean your injectors; i had the same problem as you an this cured it!
Posted: Thu May 11, 2006 3:28 pm
by hammoj28
Hmmm, im definately gonna clean my injectors first then! Would love to put a supersprint manifold on it though!
advice
Posted: Thu May 11, 2006 6:05 pm
by appletree
I thought it was very steep and am only 18 maybe he though he could make a quick buk from a lad who ca afford to own,run and insure a BMW maybe he tought daddy would pay ( He wont, prowd to say i've worked me bo@*oxs off to pay for it ) although he seemed a pritty genuine guy!
i will try cleaning the injectors first. Hows the best way? ave got an ultrasonic cleaning bath in me garage would this be any good??
Posted: Thu May 11, 2006 6:13 pm
by Dan318-is
Ultrasonic cleaning would be the best way yes (lucky bastard!)
Posted: Thu May 11, 2006 7:28 pm
by appletree
I know i bought it to clean me mountain bike bottom brackets and other parts when i used to be in to them!
Posted: Thu May 11, 2006 11:50 pm
by tim_s
before replacing tappets, try removing and cleaning them, dan's right about throwing in additives etc., unless you're particularly lazy! if the chain's being done its not much work to have the cams out and clean the tappets out.
I have a spare set of (used but quiet) tappets for a 318is btw if that's any help.
also try an oil change and some thin synth oil. do quite frequent oil changes to clean out any crap in there. make sure the old oil is warm when you remove it. mb even try flushing oil in there before the new oil goes in. might help if you have noisy tappets.
the cams can wear, but you can buy exchange regrind performance cams pretty cheap if reqd.
over a grand for the work they're on about is a hell of a lot of money. bmw themselves would be the better option if you're on about spending that much.
i would find out more accurately what's making the noise - its gotta be pretty obvious whether its water pump, injectors, or head - they're quite far apart!
the chain should only need doing if its making noise etc, and is worth trying the tensioner first anyway. how many miles you done?
ticking noise from inlet side of rocker is normally injectors, i remember dan thought his was tappets but was cured this way. worth doing as a matter of course as old injectors could harm your performance - especially as you have an ultrasonic bath!
Posted: Fri May 12, 2006 7:26 am
by appletree
Cars done 88-90,000 miles as for the last year the speedos was intermitent before i bought it, sorted now tho.
i was only gonna do the the chain and the water pump because the mechanic said he would have to take the cam chain off to do the tappets so i thought will he was there he might aswill fit new chain and water pump although they arn,t making any noise them selves.
what liquid should i use in the ultrasonic bath to clean A) the injectors B) the tappets? i only eva used degreaser before.
when i do the inectors would it be a good idea to put them in an injector cleaner like say redex??
