New member - just saying hello
Posted: Fri May 05, 2006 7:24 pm
by SD
Hi all,
Just become the proud owner of an H-reg 325i Touring.
Have been browsing the zone recently and it seems like there is loads of good info on here - car is in good nick, but there will be some niggles to sort, so will be around here to look for advice!
Cheers,
Scott
Posted: Fri May 05, 2006 7:25 pm
by fuzzy
welcome mate,tourings are the way forward,any pics? :thumb:
Posted: Fri May 05, 2006 7:41 pm
by Conan
:ttiwwp:
Posted: Fri May 05, 2006 9:08 pm
by Andy335Touring
:wave:
Posted: Fri May 05, 2006 9:09 pm
by pete320i
hi and welcome to the forum, they are a good lot on here. have with the car mate.:cheers:
d
Posted: Fri May 05, 2006 9:24 pm
by panesar_e30
any pics of the car mate? :cool:
Posted: Fri May 05, 2006 9:43 pm
by stevetigger
:tongue:
Posted: Fri May 05, 2006 9:47 pm
by zaust
Welcom to the zone fella...
pic's pic's pic's...
Posted: Fri May 05, 2006 9:55 pm
by eko
Welcome mate :)
So whats your plans for the tourer?
Standard or modified?
Posted: Tue May 09, 2006 8:37 am
by SD
Well, didn't take long to find the first "niggle". What initially looked like a small oil leak turns into Niagara falls every time the car is parked pointing uphill. Not a drop if nose down. Searching on here it would appear to be the sump gasket or rear crank seal?
Oh well, c'est la vie, knew I wasn't going to get away scot free. Am going to get it booked in the garage to take a look - and they can do the timing belt while it's in.
Otherwise, the plans for the Touring is to get it to the point where it can do exactly what it says on the tin, and take us touring! Just want to make sure it is mechanically sound, and then can look at improving.
Sorry no photos yet - but, it's Brilliant Pink with 15" BBS's. Will get some up as soon as I can take some without it looking like the Exxon Valdez! :D
Posted: Tue May 09, 2006 8:58 am
by Hyperion
Welcome SD, Sounds like a sweet ride, tourings are cool :wink: Sorry to hear about the oil leak thou :cry:
Posted: Tue May 09, 2006 10:48 am
by e30_Turbo
SD wrote:Well, didn't take long to find the first "niggle". What initially looked like a small oil leak turns into Niagara falls every time the car is parked pointing uphill. Not a drop if nose down. Searching on here it would appear to be the sump gasket or rear crank seal?
Welcome :D
And sounds like the sump gasket to me, the last few nuts by the bell housing are only hand tightened by the garages, mine had worked loose and the gasket had popped out.
Easy to find, just take out the 4 bolts on the access panel under the gearbox and have a look.
If it needs changing you'll need to drop the front beam to get enough clearence to clear the oil pickup, also lifting the engine from above may give you a extra inch or two....
And we'd all like that wouldn't we :lol: :lol:
Posted: Tue May 09, 2006 12:04 pm
by Ant
:lol: @ Fozz
speak for yourself mate :wink:
Welcome to the zone fella !
put your location in your profile and you may find a lot of zoners local, always handy !
Posted: Tue May 09, 2006 12:09 pm
by M5pilot
Welcome to the Zone!
Tourings are the in thing these days, get some pics up.
Posted: Tue May 09, 2006 1:25 pm
by Ziggy
Welcome! Look forward to seeing it at a meet sometime? There's quite a few of us in the area! :D
Posted: Tue May 09, 2006 5:47 pm
by SD
Thanks guys.
Unfortunately, the oil leak brings bad news...
http://www.e30zone.co.uk/modules.php?na ... ic&t=34992
